Question about Fahrenheat FFH1615 Heater
Fahrenheat FFH1615 no operation fail-light is on
The 5/8" button type thermal cut-out got loose then hot and failed. the numbers on the device are - 36TX11-13940-L230-70F-5620-000. My question is where can I get a replacement part?
Vity 125 cuts out after a while when the weather is hot
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Idles And Then When Reved Cuts Out
Help My Bike Keeps Cutting Out
http://www.49ccscoot.com/manuals/Yamaha_Vino_125_Service_Manual.pdf
OEM parts for Yamaha
YAMAHA VITY XC125E Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 20, 2014 | 2009 Yamaha Vity
Ybr125 cuts out at 7000 revs and engine management light flashes
9. Fuel tank empty
10. Water or dirt in the fuel system, or clogged filter.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump.
13. Failed pressure regulator.
14. Faulty or clogged fuel injectors.
https://yamahaclub.com/forums/topic/23502-ybr-125-queries
YBR125 engine light
Yamaha YBR125ED 2005 Service Manual
Yamaha YBR125ESD Owner Manual
Mar 12, 2013 | 2007 Yamaha yBR 250
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
Bike stalls after fully operating tempetures,and will cut off in gear or idoling. Then after a period of 15 minutes, then it will start again and run until it gets hot again.
Hi, Trap4mils and the usual suspects are:
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
98 2 5 TL Starts runs OK when cold stalls after reaching operating...
Stalling rough idle when hot Suzuki GSX Motorcycle Forums Gixxer com
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Yamaha YZF600RP Owner Manual
Aug 15, 2010 | 2002 Yamaha YZF 600 R thunder cat
THERMAL FUSE BLEW
A blown thermal fuse is an indication of a failed operating (cycling) thermostat. The thermal fuse and the operating thermostat are located on the blower outlet duct to regulate the temperature of the air inside the dryer by monitoring the temperature of the air going out. The cycling thermostat cycles off when the air gets too hot and cycles on when it gets colder than normal. Therefore when it fails to cycle off, the temperature gets too hot and when it reaches the temperature limit of the thermal fuse, the thermal fuse blows.
Apr 18, 2010 | Dryers
I have a Whirlpool Dryer Model number GEX9868JQ0 and it will run however; it is not blowing hot air? How do we remove the kickplate (front or back) to check out what is wrong? Please advise.
A typical problem that causes tumble dryers to stop heating up is the thermal overload cut-out devices. These are safety devices, and are some times "single-shot". That is, if they operate, and shut off the heating element, then they need to be replaced, usually as a pair along with the thermostat (they look very similar). The other common fault is that the heating element fails. However, if the thermal cut-out was the problem, LOOK FOR A CAUSE. If it is a condenser drier, check the condenser box is not clogged with lint/fluff
Oct 30, 2009 | Whirlpool GGQ8831L Gas Dryer
I have lost my instruction book and need to change the clock as it did not change automatically. Many thanks.
Not really solved yet, but my daughter is hoping to get a new instruction book.
Many thanks
Hilary Miller
Oct 26, 2009 | Fahrenheat FFH1615 Heater
Diplomat 600gs model no 050502078
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. Look for a thick (4-5 mm), button-like device customarily with two terminals (apparently some have 4) and a diameter of 1.5-2.0 cm.  Bypassing it will expose you to a loss of hearth and home if the regular control circuits fail.   Rather try this; locate the device, use a metal shield to divert some of the heat which will allow it to serve its original function as a safety.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Aug 09, 2008 | AEG B1180-4 Electric Single Oven
4 wire oven thermal overload cut out
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. Look for a thick (4-5 mm), button-like device customarily with two terminals and a diameter of 1.5-2.0 cm.  Bypassing it will expose you to a loss of hearth and home if the regular control cicuits fail.   Rather try this; locate the device, use a metal shield to divert some of the heat which will allow it to serve its original function as a safety.
Feb 21, 2008 | AEG B1180-4 Electric Single Oven
Fahrenheat FFH1615 Heater Logo
155 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
