Simplex 4010 with n.a.c. extender in a three story dormitory horns and strobes work on first and third floors only strobes work on second floor. Field wiring works fine when a 24v.d.c. external power supply is applied to the horns they operate fine. Fuses in n.a.c. extender panel check good and no trouble lights illuninated in n.a.c. panel. any suggestions appreciated . ibquiet
You have to chech the output voltage in thn.a.c. extender while making an alarm
Posted on Jun 26, 2009
I need some additional information.
Is it an adressable 4009 signal extender wired up to trip with idnet or is it hardwire trip. A part # on the 4009 would be good. The repair might require you to check programming.
Posted on Oct 28, 2008
Is horn circuit folding back "Overloaded"
Posted on Mar 05, 2008
On a two story building what is required under a window to stop water leaking down onto the window underneath on first floor
The window on the second floor and the window on the first floor should be two separate and independent water proof systems. Nothing should be required under the second floor window to keep water off of the lower window. Please, explain with more detail or pictures.
Nov 15, 2017 | Building Materials
My router is on third floor and the sky box on the bottom floor , sky box does not receive the sifgnal
You need to either move the router to the second floor, or your skybox to the second floor. You could add a jumper router on the second floor
Apr 28, 2014 | GPS
I have a E2d Defender and when I turn the light on the light flashes like a strobe light. Any ideas on how to fix? Thanks
THIS FLASHLIGHT SHOULD HAVE THREE DIFFERENT LIGHTS WHEN YOU ACTIVE THE SWITCH TO TURN IT ON.FIRST IS THE BRIGHT,SECOND IS THE LOWER BRIGHT AND THE THIRD IS THE STROBE.YOU SHOULD BE ABLE TO ACTIVATE ALL THREE FUNCTIONS OF THE LIGHT BY PUSHING THE SWITCH.HOPE THIS WORKS.IF THIS DOESNT WORK THEN THERE IS SOMETHING WRONG WITH THE SWITCH.
Nov 27, 2013 | Surefire E2D Defender Flashlight
Wet Floor at Third Seat
your ac drain is blocked
Jan 17, 2013 | 2008 Ford Expedition
Check engine light came on, diagnostic revealed oxygen sensor, replaced all oxygen sensors, drove the car for 50 kms, stopped and restarted the car and after a few minutes, the light came on again. What ...
the beginning of yourproblem is misdiagnosis, you probably had it code scanned,and got an 02 code, if you had it on a real time scanner you would get readings from the scanner to assist in diagnosis, story i tell my assistants, the floor is wet, first guy mops it up and leaves, second guy noticed water dripping on the floor, so he mops it and places a bucket to catch the drips. third gut sees the wet floor, notices the drip , looks up an notices the roof is leaking, so he fixes the leak and mops the floor, same idea with cars, you get the symptom but you have to find the cause to repair right, so find a tech with a real time scanner and take the time to do it right
Nov 20, 2010 | Ford Windstar Cars & Trucks
How to make a d-link 264 ob into a repeater I have a three story house with wireless on the ground floor and the signal is very poor at the top. I want to repeat the signal on the second floor.
Move your wireless to the second floor or add a second wireless router to your second floor. Use CAT 5 or 6 cable. Run it in a closet or cold air return. Use the special cat 5 or 6 for cold aire return use. Do not put it in a heated duct.
Dec 09, 2009 | Computers & Internet
2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
Apr 04, 2009 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
340 people viewed this question
David Payne
David Payne
