Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Image wrap with adf
Xerox workcentre xd103f shifts the image off the left side of the paper about 3 inches and then wraps that part of the image onto the right side of the paper when copying something through the ADF. The flatbed glass copying works perfectly every time, but the ADF wraps the image about 50% of the time. There is absolutely no skewing. The image is as straight as can be all the way down the page even when it wraps. The ADF always feeds perfectly and the mirrors and lens and CCD are all tightly in place.
  • copier user Jan 27, 2008
    Thanks "tryit",
    I had managed to fix the problem through adjustments and cleaning, but I was curious as to what this code did, so I tried it. It does appear to reset the software completely including all of the counters (even the drum and machine life copy counts). I did have to go back into the diagnostics and adjust the automatic magnification front to rear and the lead edge to trail edge. I also had to adjust the lead edge registration and the center offset. I also had to enable the ADF and set the unit to inches along with disabeling the paper bypass auto start.
    I would not recommend this code to someone who does not have access to the complete internal list of adjusment codes or they would be very unhappy with the resultant copies.
    However, since I did have the entire list, I would like to thank "tryit" for his information and research.
  • 2,072 Answers
You have to reinitialize the software. I will be back in a few minutes with the procedure. I have to hunt it up.
Posted on Jan 24, 2008
  • Rick Kasper Jan 24, 2008
    Sorry it took so long, The server was down.
    Do the following
    Press the following buttons in sequence within 4 seconds:
    Clear, Auto, Clear, and then the 100% button.
    - The display will go blank.
    then enter 88
    then enter 1 to reset.
    That should resolve the issue.
  • Rick Kasper Jan 27, 2008
    Well I agonized about posting that.
    I may have misunderstood what your problem looked like in actuality. But I concluded you had software corruption.
    I have seen, what I think your describing and it requiring a reset.
    Yes, I agree if anyone else trys this, be sure you have documentation to readjust the settings that are held in the Non Volitle Memory. Or else as you correctly stated, You will NOT like the results.
    I am glad to hear you have your issue resolved.
    That is a excellent machine. Usually runs well.
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Why image output comes lines?
If you're referring to copies fed through the adf, clean the adf glass strip on the left of the platen.
Apr 02, 2015 | Xerox Workcentre 7345 Printer, Copier,...
I have received an error code of 010-327 and I need to know what this is
Fuser thermal error. Check for paper wrapped around the rollers, but you will need to replace it.
PN 126K24980
Item, Inc.
Jun 25, 2010 | Xerox WorkCentre 52255230 Copier
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Workcenter xd103f copy comes out blank
Which cartridge did you change? If its the toner cartridge, make sure none of the packaging materal is left on it, same with the drum cartridge. First and simply remove and reseat the cartridges.
What I suspect with the blank copies is a broken transfer corotron wire.
Open the right side door. On the bottom you will see some whit plastic rollers. Above that you will see an opening about 1/2 inch wide. There is a very thin wire in that channel. That wire has probably broken causing your blank copies, I highly suspect that is broken.. That wire when it is dirty also causes really poor copy quality.
Also clean all the mirrors and glass well. That will cause poor copy quaility issues.
Mar 12, 2008 | Xerox WorkCentre XD103F All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
112 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
