Question about Magellan MAESTRO 3100 98083401 GPS Device
Navigation my gps is telling me its somewhere else, but im home? also it keeps tuning on and off/ pressed reset stayed on two bars on baterry? still telling me its somewhere else? looked at satellites only two not good huh?
I have had similar problem before. Reset it several time and make sure you have enough charge.
Posted on Jan 24, 2008
Baterry keeps draining
You have an electrical short somewhere that is alowing electrical components to stay powered and drain the battery.
Mar 31, 2017 | Cars & Trucks
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
My wife is south of edmonton, Alberta and going to Lloydminster and is totally directionally impaired. The GPS is still stuck on our home here in Richmond BC and can't get a gps signal....what can she...
well, keep the GPS under clear skies for 1-5 minutes and see if it can lock any satellites. if not then after 5 minutes while in that screen reset it by pressing the small pin hole reset button somewhere on the GPS and let it restart , should come back to normal.
Good luck
Jul 29, 2010 | GPS
Wrong location
You need to update the firmware. The newer firmware will use the satellite for your location.
Dec 16, 2009 | Garmin nuvi 1300 Car GPS Receiver
I have been having trouble with my roadcom sat nav, I used it to get somewhere and had no problems but when I went to turn it on to come home, the main screen comes up but it just freezes and it wont let...
To hard reset the unit turn the unit off, hold down the mode button and turn the unit on. When the unit asks if you want to erase all user data, select yes. After resetting the unit, leave it with a clear view of the sky for about 30 minutes to acquire the satellite almanac. “ Do not worry You don’t loose Your saved rides data, only all screen settings and some other device settings will go away. Set it back to Your preferences and You’re done. Hard reset is suggested after software updates. In my case it heals all self shutdown problems in my Edge 705 GPS.
Dec 02, 2009 | Garmin Edge 705 Satellite Navigation...
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Too easy..
Click on "WHERE TO?".
Then click on "FAVORITES".
Scroll down until you find "HOME", not the green bar on the top but scroll thru the favorites until you find "HOME" and select it.
Click on "EDIT", then on "DELETE".
Go outside your house, get a good satellite signal and click on "VIEW MAP".
You should zoom in or out according to your preference and click on the vehicle icon, as your are standing outside your house and...that's it! Just click on "YES" and enter the name as Home when it asks you "DO YOU WANT TO SAVE THIS LOCATION AS A FAVORITE?" You can even change the icon and enter other info...good luck!
Dec 01, 2008 | Garmin nuvi 200W GPS Receiver
First thing ensure that the TomTom is fullly charged using the home charger.
Press the small reset button on the base (700) or do a factory reset.
The other thing to try is tap the GPS signal bars to go to the configure and check in the top right hand corner there is a circle with yellow and black esgments if this is moving then your TomTom is looking for a signal. Move around and you should find that the bars at the bottom will start to move and the small screen on the right will start to indicate circles. When the bars start to move you are getting GPS signals when the bars change to blue there you have a coordination for your position. Some areas are worse than others so move out of your house if after doing above does not get a signal
Aug 14, 2008 | Tomtom ONE 3rd Edition GPS
How to change home map on used Garmin i3 street pilot
Hello. Had the same problem and just solved it.
Do this.
Tools -> Manage My Data -> My Locations. Position to Home and then click Manage -> Change Location ..
Sep 15, 2007 | Garmin Map Source City Navigator
Magellan MAESTRO 3100 98083401 GPS Device Logo
44 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
