Question about Ensoniq (6000708) Sound Card
NO AUDIO DEVICE
When i go to control panel and i got to sound and audio, it says that there isnt an audio device how do i fix that. I have an MSI motherboard and my sound card is on board. Can someone help soon
    Champion:
  • 207 Answers
Ok...do you have intallation CD of your sound card? if you have, install this to your computer.
try to reseat your sound card and detect it through add hardware wizard.
Posted on Jan 23, 2008
6ya staff
SOURCE:
I have no sound , i am useing onboard sound on the msi p4m900m3 mainboard
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 30, 2011 | MSI P4M900M3-L Motherboard
Hi im using ms-7312 ver.1.0 motherboard newly formatted by sound is not coming pls help me
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | MSI K9MM-V Motherboard
Audio device not detected
if you are having problems with your sound
also
hope this helps don
Mar 14, 2011 | MSI K8MM-V Motherboard
Hello, the built in sound card is not working. it says the sound driver is not installed. the exact model of my board is msi ms6850 ver:5. where can i find a driver download for this?
also
hope this helps
don
Feb 27, 2011 | MSI MS-6580 Motherboard
I cannot download msi ms7095 on boad audio driver
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 06, 2011 | MSI : P4MAM2-V (7095-010)...
I want sound drivers pls
also
hope this helps
Feb 04, 2011 | MSI 661FM3-V Motherboard
No audio output device is installed
you might have to get a portable usb sound card if you mean dont have a sound card installed or
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 02, 2010 | MSI 845GVM-L (MS-6714-040) Motherboard
Sound driver installed but no sound
start->control panel->sound speech & audio devices->sound and audio. Now make sure your audio device is present under the Audio tab in the Audio Playback. Also make sure you are not muted.
Jun 04, 2009 | MSI P4MAM-V (MS6787060) Motherboard
Audio device not found
is the sound device is built in to mainboard? if yes the you can download the driver of your audio here:
http://global.msi.com.tw/index.php?func=downloadindex
just input necessary data for the download.
Jan 23, 2008 | Ensoniq (6000708) Sound Card
No audio device
Hi, just Google the MSI website, click on download and support,
Locate your board and click the link for downloads for it. You will find Audio drivers listed there. With MSI it is usualy Realtekaudio97.
Regards mistyman
Oct 12, 2007 | Creative Labs Sound Blaster Live! 5.1...
Ensoniq (6000708) Sound Card Logo
55 people viewed this question
Top Ensoniq Computers & Internet Experts
Alun Cox
Are you an Ensoniq Computer and Internet Expert? Answer questions, earn points and help others
