Xerox Workcentre XD130df error
Can you please assist me in finding what the error A1 means on the Xerox Workcentre XD130df? Is that a toner or something and if so, which one? Thanks in advance.
  • oneluckyone Jan 23, 2008
    Got it working. Thank you!
  • 239 Answers
This code is in the document handler.
if you can check to see if there are any small pieces of paper in the paper paths. use a double paper folded and run it down the paths, they should go right through.
If it is still on one of the sensors might of popped out of place, it may need to be put back into place. These document handlers are pretty reliable.
Also on the back lef corner is a white plasic lever sometimes these do not seat well on the mount itself. Check to see if this plunger goes up and down properly.
If the document handler does run, try to clean the feed wheels.
If all comes to worse, Call Xerox Serivce for a major repair on this machineThis can be mechanical clutches on the feeder itself or the document feeder circit board.or sensors.
Posted on Oct 16, 2009
    Scholar:
  • 53 Answers
Not familiar with XD 130 but A1 in most Xerox machines refers to a jam in the document feeder, open everything you can and look for torn pieces of paper on a sensor
Posted on Jan 23, 2008
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
L6 Code
The Laser's Polygon Motor has failed to reach proper speed in the allotted start up time.
Replace the polygon/laser assembly.
Jun 19, 2009 | Xerox WorkCentre XD130DF Laser Printer
New toner xerox pe220 laser and it prints dark pages now
Make sure the electrodes between the drum unit and the printer is clean. Use a soft cloth or Qtip to clean, maybe slightly moisturized with vodka (not kidding). Vodka is actually perfect for cleaning most stuff that needs cleaning in printers, even the photosensitive layer on the drum if there happen to be dirt spots on it (gentle rubbing with Q-tip, very carefully).
Also clean the corona wire as per instructions in the manual, don't know your particular printer but there is usually some kind of knob on the drum unit that you are supposed to use for this purpose.
This should fix the problem.
May 21, 2009 | Xerox WorkCentre XD130DF Laser Printer
Installed new drum on my xerox xd130df. Won't print.
Could simply be out of ink ,that machine will sometimes not detect an empty toner cartridge and just sit there kind of dumb...
Mar 27, 2009 | Xerox WorkCentre XD130DF Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
L6 code on a Xerox XD130 DF
Yes, and L6 means the main board is not detecting the operation of the motor that runs the mirrors in the laser.
In order of probability , the laser is bador the main board.
Jan 14, 2009 | Xerox WorkCentre XD130DF Laser Printer
Xerox XD130df empties toner back into cartridge overflow
that really sounds like a defective toner cartridge. Either there was no developer in the cartridge or the metering blade that limits the ammount that gets onto the roller is bad.
Has to be the toner cartridge. Unfortunatly that may have also ruined the drum and cleaner within the drum cartridge. Return them for an exchange.
The reason it is running and running is that it is trying to read a patch that is developed on the drum and add toner to make a dark enough copy. And that definatly is not happening.
If the laser was not turning on, the machine would come up with a L something code. Besides if the laser was not comming on, the paged would be blank.
You can pretty much eliminate everything but the toner cartridge.
Sep 22, 2008 | Xerox WorkCentre XD130DF Laser Printer
XEROX WORKCENTRE XL2120
J2 means the drum cartridge needs replaced.
Its next to the toner.
Jul 14, 2008 | Xerox WorkCentre XL2120 Laser Printer
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
130 people viewed this question
k24674
jasbo
jasbo
