Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No power ... no nothing
I came home yesterday went to turn on tv and it made a noise like it was turning on but indeed it shut completely off. since then I have absolutley nothing. no blinking lights...no lights at all to even show there is power connected to it. even the standby light won't even come on. it appears to be a bad power supply or something. I've unplugged it for 24 hours and plugged it back in and still no standby light no power no nothing. Any suggestions.
Thank you in advance.
Jerry
    President:
  • 4,402 Answers
Power supplies give a lot of trouble (besides the tube). there are two regulators that go bad very often. they may also take out the horizontal output. there are some capcitors, resistors, 2 thyristors (i believe 2) and diodes that are suggested to be replaced along with the two regulators. all of those parts are fairly cheap so it shouldn't be that big of a deal to repair (granted that is the problem and the only problem).
Posted on Jan 23, 2008
6ya staff
SOURCE:
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Why does it seem as though my battery is completely dead but it isn't?
A bad cell could have too much internal resistance when the battery has to draw many amps to turn starter over. Put headlights on then hit the starter, if the headlights go off, the battery is bad or a connection at the battery cable or ground cable is dirty.
If you have a voltmeter, attach to battery and notice voltage of ~12v or greater, then hit starter, if battery is bad, the voltage will go from ~12v to under 9v and result is starter won't turn over the engine.
Feb 15, 2016 | 1998 Dodge Neon
Tv turns on but has no picture
there might be a high voltage leak from the plyback.Open the back cover of your tv .turn it on and observe which part of the plyback has a leak..use a silicon adhesives to cure the leak..cover it heavy and complete..
tnx please rate my help.
Jun 04, 2010 | Samsung TXN3071WHF 30" TV
SONY KV-32FS13 No Power.. No nothing
has a power supply or deflection fault requires service
Mar 16, 2008 | Sony KV-32FS13 TV
TV went out
Hey Jim, The high voltage protection circuit has gone out on the D-board and will need to be replaced. The fuse to the power supply is probably fine. A good repair tech shouldn't charge over $125 for this and it only takes a couple of hours. Let me know if I can be of further assistance.
Jul 17, 2007 | RCA F27242GY 27" TV
TV will not turn on
Probably needs a new HV Splitter block, they are very difficult to replace and can usually be accessed thru the front behind the speaker grill and behind convergence board.
Mar 18, 2007 | RCA P46924 46" Rear Projection Television
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
