Question about Royal Satellite 80 Typewriter
BROTHER TYPEWRITER MY PAPER WILL NOT TURN FROM LINE TO LINE ON MY BROTHER TYPEWRITER. WHEN YOU ARE FINISH TYPEING ONE LINE, THEN HIT THE RETURN KEY IT WILL NOT MOVE TO THE NEXT LINE. HOW TO I FIX IT
  • ANNZOE Jan 23, 2008
    can i take it off and buy another part and fix it myself
  • 398 Answers
Is your typewriter made by Royal or Brother? I think your question was mis-posted under Brother as opposed to Royal. IF your machine is a Royal, Brother will NOT be able to help you. THIS GOES FOR EITHER MANUFACTURER...Have you inspected the platen drive gear? Is it cracked, missing teeth or otherwise damaged? If not look on both sides of the typewriter for the drive motor. Look to see if the gear mates with the motor.
Posted on Nov 19, 2011
  • 478 Answers
The platen drive gear attached to the platen drive motor is most likely broken a common problem on Brother typewriters it is pressed onto the motor shaft. They are available from Brother
Posted on Jan 23, 2008
Problem with the line spacing on my brother sx-4000 typewriter. The spacing wheel is not moving the paper down to the next line. I've moved the lever on the right side back and forth to see if it...
If all the settings are right and it feeds with the platen knob the plastic gear on the index mitor is probably broken the part is about 25.00 plus installation.
DickyO
Jun 07, 2011 | Brother SX-4000 Typewriter
WHEN I TYPE SOME THING AND HIT THE SPACE BAR THE RETURN BAR IT TYPE ON THE SAME LINE AND EVERY THING IS IN ONE .
If the paper will move up with the platen knob the paper feed motor probably has a broken plastic gear. The gear and motor are sold as one 35.00.
DickyO
Mar 15, 2011 | Brother GX-6750 Typewriter
Can I make my typewriter go to the bottom of the page without turning the wheel? Have a lot of pages and wrist hurts after a while!
The paper should line space after depressing the return key. Check the settings. To remove paper quickly, pull the paper release lever.
Nov 11, 2009 | Brother SX-4000 Typewriter
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
How to install min L MAR on the Brother Typewriter AX-450
move the printhead to where you want the L MAR set then hit the L MAR button, if you want to move to the left of where the L MAR is set, go to the L MAR by backspacing or  the return key, hit the MAR REL button and backspace to where you want the mar set and hit L MAR.  the right margin works the same way
Feb 25, 2009 | Brother Office Equipment & Supplies
Ink cartridge pops up when the return key is hit...
go to http://www.brother-usa.com and you will find a printable user's manual for all models
Dec 04, 2008 | Brother GX-6750 Typewriter
Brother typewriter sx 4000
make sure the ribbon and correction tape are installed correctly between the metal fingers on the far side of the printwheel and the cardholder. make sure there is no forien objects in the P/W or anything touching the petals on the P/W. turn mach. off for 10 secounds then back on or just hold down the code key and hit the Q (reset) if it still doesn't work, it will need repair or replacement.
Nov 04, 2008 | Brother SX-4000 Typewriter
Typewriter troubles
First,the paper problem is most likely that your paper release lever is in the forward position,just click it back and you will find that the paper will stay in place and space upwards when carriage return is pressed. Make sure that the printing unit can move freely to both extremes of its travel when the machine is turned off. Lift the top cover up and move the print unit by hand, it will feel stiff but it will move. If all this is in place your problems are over....
Nov 03, 2007 | Brother GX-6750 Typewriter
Brother gx-6750 typewriter
Make sure the knob for the platen (roller) is tight. Hold the roller and turn the knob to tighten.
Jun 24, 2007 | Brother GX-6750 Typewriter
Royal Satellite 80 Typewriter Logo
220 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
