Question about Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 Fax machine error "offline"
Can anyone suggest how to get the Brother MFC 8500 fax machine to stop displaying the "offline" error message, and accept faxes? It just stopped working out of the blue. thank you very much
  • 5 more comments
  • meganmehta Jan 23, 2008
    There is a dial tone when I pick up the phone on the fax machine. Any other ideas?
    The error message says "Pls open cover" on the first line, and the second line says "OFFLINE". The last thing I did, (i think) was send a fax to someone.
    if I disconnect the cable of the fax machine, won't the memory disappear, and so I will lose whatever faxes are on the way to me, or on the way to someone else?
    SOMEONE PLEASE HELP ME!
    Thank you SO MUCH, it is "online" again, after I unplugged everything and powered down and then plugged everything back in. thank you!
  • Anonymous Mar 19, 2014
    Message present on my brother fax machine
  • Anonymous Mar 29, 2014
    How can I change the resolution
    Scholar:
  • 128 Answers
Call Brother Customer support at 1-877-BROTHER (877-276-8437)
Hope this helps :)
Posted on Jan 23, 2008
    Novelist:
    Scholar:
  • 136 Answers
I think its the drivers for the modem on your machine that has died. Try reinstalling the fax drivers the machine. Also if you have multiple phones using the same line disconnect all of them first before you troubleshoot your modem.
The fax component of this machine is done via your PC so your modem drivers is probably the problem child. Go to device driver, navigate to the fax device and see if there's an exclaimation mark next to it. If there is that is your problem. You should right mouse click it then update the drivers from the install disk or download the latest drivers.
Good luck.
Smeags.
    Genius:
  • 1,067 Answers
Try to pull the toner out ok wait min then put it back in see if erroer goes away is ther button on it to set offline online in menu im getting the manel for u give me a few
  • nick helpap
    nick helpap Jan 23, 2008
    Power off the printer for 15 minutes and power back on again. If that fixes the problem then OK.
    If not then go into maintenance mode -
    Press and hold the menu/set key while turning on the machine. Wait until it comes completely up before releasing. It should say Maintenance in the display.
    If not press function,*,2,8,6,4 within two seconds. It should say maintenance in the display. Or on some machines Menu,*,2,8,6,4 within 2 seconds.
    Once you get it into maintenance hit 91 to do a parameter reset and than 99 to get out of maintenance.
  • nick helpap
    If your fax machine is set to Easy Receive ON, it is more
    sensitive to sounds. Your fax machine may mistakenly
    interpret certain voices or music on the line as a calling
    fax machine and respond with fax receiving tones.
    Deactivate the fax by pressing #51 if you are at an
    extension phone or press Stop/Exit if you are at the fax
    machine or an external phone.
    Try avoiding this problem by turning Easy Receive to
    OFF. (See Easy Receive, Page 5-3.)
    Sergeant:
  • 226 Answers
Ok. right click on my computer,
click on manage,
click usb ports,
delete all files named composite device.
unplug the cable from your printer
restart your computer.
plug it again the cable.
start your printer.
good luck...
    Champion:
  • 207 Answers
Can you tell me the what specific message on your fax machine? what's the last thing you did before the error encountered?
  • 3 more comments
  • Gil gil
    Gil gil Jan 23, 2008
    go this website: www.brother-usa.com/support/ so you will be assisted more on your error concerns.ok?
    You can also contact thier thier technical support for more info.
    trust me, it helps!!
  • Gil gil
    oh, by the way..i almost forgot..go to this very important link: http://www.brother-usa.com/Manuals/Defau... you can dowload you manual intstructions guide and troubleshoot your errors here specifically on your printer.
  • Gil gil
    try to reconnect your cable of your fax machine then restart your machine at once..
  • Gil gil
    i don't think coz it has self-retaining feature that it will store your data even if the cable is disconnected and reconnect..
  • Gil gil
    or much better and safer convinience for you..try go to this link:http://www.brother-usa.com/Manuals/Defau... then dowload your specific manual of your machine.ok?
  • 871 Answers
Is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
  • earl norman llanera
    earl norman llanera Jan 23, 2008
    hi again
    what we can do for you now is follow this steps
    unplug the phoneline from your faxmachine...
    turn off your fax and unplug it...
    wait for 5 minutes since we just need for the machine to power down...
    after 5 minutes, replug your fax machine but dont turn it on yet.
    re connect the phone line to your faxmachine and then turn on the machine...
    so what does it say now?
We have a Brother MFC -8500 fax machine. Every day
The Drum unit is a consumable.
Buy a new Drum from Staples , Office Max etc and replace it soon.
It will stop and refuse to print when a certain page count is reached.
Jan 07, 2011 | Brother IntelliFAX 2800 Laser Fax
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Brother MFC-8500 Fax Error 77
Error 77 is a fuser error. If resetting the power doesn't work, then the fuser is bad and it will need replacement. Repair should cost around $200-250.
Jun 13, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 receives faxes and does nothing else
Check to make sure that the PC Fax Function is turned off. I noticed after I connected the 8500 to my PC and installed the software, I too could no longer receive faxes and it was corrected after I turned this PC Fax function off.
The function is located by:
  1. Press the MENU button.
  2. Select Option 2.
  3. Select Option 1.
  4. Select Option 8 (PC Fax) and turn that function OFF.
Hope this helps!
Apr 28, 2008 | Brother MFC 8500 All-In-One Laser Printer
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
MFC-8500 fax operation
If there is noise on phone line machine reduces speed to enable fax to be sent. Have line check or try machine on different phone line to ensure it is a phone line problem.
Dec 03, 2007 | Brother MFC-8500 All-In-One Laser Printer
Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Jul 24, 2006 | Brother MFC 8500 All-In-One Laser Printer
Brother MFC 8500 All-In-One Laser Printer Logo
668 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
