Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco vienna superautomatica
The grinder on my machine seems to be just making noise and no longer grinding the beans. I brought it to a repair shop in my area only to have it break 3 more times after only grinding 3 to 5 cups of coffee. Can anyone help. I love my Saecco but have it stashed away because it just will not stay working.
  • Anonymous Sep 26, 2008
    Grinder stopped working red light stays on. Will try the toothbrush method as all of the sediment wasn't removed initially. Any other suggestions?
  • tcam0678 Oct 12, 2008
    I push the brew button, but the grinder does not start. Instead the green light flashes for about 15 seconds and then the red light comes on steady. About a week ago the grinder did sound a little funny. Any suggestions would be appreciated.
    Thanks
  • 2,039 Answers
Oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Posted on Jan 23, 2008
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Our Saeco Vienna Superautomatica sounds like it's grinding beans but keeps running until the red 'bean' light comes on and we have to shut the machine off. Any suggestions?
The grinder is timing out and stops if the beans do not enter the grinder. This happens because:
1- The grinder outlet is clogged and fresh beans cannot pass through the burrs.
2- The grind setting is too fine and helping clogging in the grinding chamber or the ground coffee outlet.
3- Operator may have been using dark roast oily beans. Like it or not, the dark roast oily beans do not make stronger espresso. Please stop using such beans in fully automatic espresso machines.
4- The grinder has already made over 2000 grinds and the burrs are blunted and not grinding beans as needed.
To solve this malfunction, clean the grinder. Make sure the grinder outlet to the doser is cleaned. This outlet passage is about 2 inches or more. To clean it, lay the machine on its back (water tank side) to allow better view of cleaning the doser and the passage of coffee from the grinder to the doser. Use the link below to find instructions for cleaning the grinder and replace the burrs.
Gaggia Titanium and Plus Espresso machines parts and repairs Saeco...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 18, 2014 | Coffee Makers & Espresso Machines
Trying to figure out which direction to turn the knob inside the coffee bean grinder to make my coffee weaker. Others have told me that the finer the grinds, the stronger the coffee. And the courser the...
HI
You can run more water through the same grind you are using now or you can trun the big knob in the bean hopper to a larger #. That will make the grind coarser. You can turn the knob to a larger # anytime but to turn it to a smaller # it has to be grinding or you will damage the grinder. If you have 2 knobs in the bean hopper, you can turn the small knob down towards the -(minus) and reduce the amount of coffee in the brew unit.
Apr 17, 2011 | Saeco Vienna SuperAutomatica Coffee...
I just received a used Saeco Vienna SuperAutomatica and I can not get coffee to brew. Drive grounds are shot into discard bin
HI
You must have 2 knobs in the bean hopper, or the grinds are more like French Press (very large grinds) If yoou just have 2 knobs turn the small one towards the minus (-) a little, and see idf that helps. If you hqve very large grinds you grinder has seperated and needs to be replaced.
Oct 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Coffee machine will not grind the coffee beans?
Since your grinder makes noise and the problem occured suddenly, I would rule out a grinder problem. I am guessing that your grinder runs 10-20 seconds before it stops. If that is the case you need to look for a obstruction in the grinder or a failed microswitch on the doser. Either of these could cause the problem.
Dec 13, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna grinding issue
I think so, most problem with that the grinder grind to the lamp light up is damp in the grinder or oily beans.
if you have two adjustment knob in the bean hopper then the second problems can be the micro switch in the machine that have to be replaced.
Best regards
/Mirran
Nov 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Limited coffee output
sounds like normal wear and tear, but i do suggest a advanced cleaning of your coffee maker.clean your bean hopper out and sanitize it good, check your owners manaul for tips and tricks on getting the most from your model!
Dec 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Jun 04, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
312 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
