Question about Bose Lifestyle 12 System
Volume will not turn down.
When I turn on my Bose system the volume is turned all the way up and I can not turn the volume down with the remote or the head unit. I need to turn the head unit off and on three or four times before it works right.
Every time when i turn on my bose system the volume is all the way high in all the modes eg - aux,vedeo.... ,then i can make it less manually on remote/front keys on music senter.
Posted on Mar 07, 2008
Bose system is just over 1 yr old, hooked up to Smart Tv ( same age) sound was working fine, turned volume down, no sound at all after that
Hi, You have a Bose Home Theater System hooked up to your television and I'm wondering if you're controlling the volume through the Bose Home Theater System or the television because both have a volume control and if you have the television volume turned down and you're using the Bose Home Theater System for volume or visa-versa then you're not going to get a decent sound. I hope you know what I mean...... CHEERS..
Mar 31, 2016 | Bose Audio Players & Recorders
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
Dec 27, 2012 | Bose Solo TV sound system - Black
My dish network remote will turn the bose unit on and off, forward dvd and ect. It will not turn up the volume.
It may be that you are not using the correct code for yourparticular Bose component. I would recommend trying all of these codes: 761,664, 656, and 639. If you are still not able to use your DISH remote to controlthe volume of your Bose component, try doing a power scan. Press and hold theAUX button on the top of your DISH remote until all the mode buttons on the toplight up, then release. Press 2 then * on the number pad, press the powerbutton at the top of the remote, then keep pressing the up button on theremote. Continue doing this until your Bose unit turns off, once it has, stoppressing the up button and press the pound (#) button. Check that the code works by trying several differentfunctions on the remote to make sure it properly operates your Bose component.Keep in mind that some codes may not be compatible with your equipment.
Thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Support Representative
Nov 21, 2010 | Bose 35503 Remote Control
When I turn my system on the volume is full blast, can not control from unit or handset.
I have the same problem with my Bose ... when you turn on the Lifestyle... its fulllllll blast. What the heck... we've had it for many years and it's been fine for all this time... Can you help me please. Everything works on the remote BUT the volume. OH, also... nothing works on the lifestyle unit whatsoever. no buttons functional on the unit... only the remote works... except for the volume... been this way for years. What's up...? any ideas how to fix it?
Nov 21, 2010 | Bose Lifestyle 20 System
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
Bose lifestyle 38 has power but will not function at all. The display reads Bose Lifestyle - Try to turn on radio and nothing happens. Tried using remote for second zone and the remote display said no...
The sub is bad.the power supply inside the sub is your problem.If your unit comes on it could also be a defective dsp pcb in the sub.everything in the sub runs the head unit.If you send to bose they have a 175. flat rate.
Feb 12, 2010 | Bose Lifestyle 38 System
The volume control on my Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
Nov 28, 2009 | Bose Lifestyle 38 System
Bose 321 system - volume is stuck at 30
You'll need to go into the main menu and there is where you can change your on volume, minimum volume, and maximum.
Apr 02, 2009 | Bose (321GS) System
Whining noise @ acceleration?
You have a bad ground somewhere. You also may nneed to replace your spark plug wires. The deck is getting interference from the engine due to a grounding problem.
Best of luck
Jan 30, 2009 | Panasonic CQ-C3301U CD Player
Volume control
I had the same problem as this, but have lost my remote, so the system is know useles. Any way back to the point if you wiggle the cable around that goes in the speaker zone port then turn it off and back on then it should work :-D.
Jan 18, 2009 | Bose LIFESTYLE 28 Series III System
Bose Lifestyle 12 System Logo
427 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
