Question about Motorola Mobility H700 Wireless Headset
Bluetooth not charging
My bluetooth won'''t charge when i plug it in.
  • 3 more comments
  • Pillan Jan 29, 2008
    I bought my H700 blue tooth yesterday 1/28/08, but it won't charge. I had it on the charger all night, but it still will not turn on when I try.
  • Lalock Feb 06, 2008
    Motorola H700 will not charge when plugged in. No lights come on when it's plugged in.
  • HETHURZ32 Feb 06, 2008
    I have the same problem. This headset has worked fine for months, and just last night I went to charge it and the solid red light has stayed on. Normally it changes colors (to green?) and for some reason the color has stayed solid. I don't know what to do. I've even tried different wall outlets to see if that was the problem and it was not.
  • mslpl Feb 19, 2008
    I have the same problem. Mine charged just fine the 1st time but wont light up or charge now. Can I get a new battery are is it cheaper to just replace the bluetooth?
  • resa1107 Aug 27, 2008
    Want charge it wet and light will not come on.
  • 2,351 Answers
The internal battery is bad or your charger is faulty, got a kink in the cord.
Posted on Jan 26, 2008
I believe this bluetooth needs to be completely charged before you can use it. My went dead and has literally been charging for 1.5 days. It has finally charged enough to turn on when I use it.
Posted on Jul 23, 2008
  • Megan Fehr
    Megan Fehr Apr 10, 2014
    same with mine except died again withing 1/2 day, i plugged it in again overnight and it still didn't chrage
2 Suggested Answers
  • 1239 Answers
SOURCE: charging bluetooth
hi sir..
please do u have muiltimeter just verify whether the voltage is there ..
Posted on Sep 02, 2008
My blueant s4 won't charge
It must be a battery problem as the battery indicator level says full when you remove it from the charger and the phone doesnt work.
Mar 19, 2013 | Blueant Ant S4 Handsfree Voice Controlled...
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
My Sony Ericsson Multipoint Bluetooth headset VH410 won't charge
light is not flashing only red light is coming on charging from last two days
Sep 18, 2012 | Sony Ericsson Multipoint Bluetooth Headset...
My Motorola H730 won't stay charged
Are you charging with boom closed and closing boom when not in use?
Motorola Support
May 29, 2012 | Motorola Mobility H730 Bluetooth Headset
Mki9200 won't list itunes
If you don't find a solution good luck with custemer service
May 26, 2012 | Parrot Mki9200 Advanced Color Display...
How do I pair a RocketScience Tracer bluetooth?
    • 1How to Pair a Bluetooth Device With an iPhone On the iPhone, click on the "Settings" icon. It looks like a gear. Then press on the "General" button. Select "Bluetooth" and then "Turn Bluetooth On." The phone is now ready to be connected to the Bluetooth device.
    • 2 Connect the iPhone Bluetooth travel cable that comes with the iPhone-approved Bluetooth device into the USB 2.0 port on the computer. Do not plug it into the USB port on the keyboard.
    • 3 Connect the iPhone to the other end of the cable. The cable goes into the data connection slot on the bottom of the iPhone. There is another slot on the top of the cable into which the Bluetooth device should be plugged in.
    • 4 Wait while the computer loads to recognize there is something plugged into it. Either a screen will pop up or an icon will appear on the desktop to let you know that the computer is recognizing there is a iPhone plugged into it.
    • 5 Let the Bluetooth device charge with the iPhone for about one hour. You can tell when the device is fully charged by viewing the status light on the device. It will be an amber color until it charges completely. Once the charge completes, it will turn green.
    • 6 Remove the Bluetooth device and the iPhone from the cable that is plugged into the computer's USB port. Push the button on the top of the Bluetooth device. This allows the calls to now go through the Bluetooth device instead of straight to the iPhone.
Jan 02, 2012 | Apple iPhone 3G
Lost pairing?
First when ya call connects, hit the Menu key (three lines inthe center) choose USE HANDSET.
Second Make sure the Bluetooth is fully charged, andit seems to lose charge fast.
Dec 15, 2007 | Motorola Mobility H300 Wireless Headset
RAZR/bluetooth light/charging problems.
From the symptom it indicate that the bluetooth having charging thing you can do is to ensure the charge contact ( both charger & bluetooth ) is good ,mean you may need to do some cleanning.if still can't hold the charge then the battery in bluetooth may need to replace. hope it help.
Aug 24, 2007 | Motorola Mobility Bluetooth Headset H3 for...
Motorola Mobility H700 Wireless Headset Logo
3,890 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
