Question about Kirby G4 Bagged Upright Vacuum
Manual I need a manual bad!
  • 357 Answers
Posted on Feb 06, 2008
    Sniper:
  • 112 Answers
Http://www.greatvacs.com/kirby%20instructions.shtml
this site's first page tells you how to put the kirby in the upright vacuum configuration...at the bottom of this page are links to how to use the shampooer, attachments, and detailed instructions on removing/attaching the powerhead.
hope this helps!!!
Posted on Jan 28, 2008
The system was turned on manually to vaccum out the car and now the only way to turn it off is to unplug it (i.e. pressing the switch on the vaccum canister to auto from manual does not turn it off). Bad...
It is possible that it is a bad switch/circuit board on the unit. If your unit is less than 7 years old that should also be covered by warranty (manufacturer) however an in home service, should you require someone to come to the house will not be covered.
Nov 03, 2010 | Beam Industries 2775 Serenity Plus Central...
I need a instruction manual for a sears kenmore single dial sewing machine model 158
Most manuals I can find for free online, but I have been looking for quite some time for a 158 manual and the best you can do is $5.00 for the one I will link you to at the bottom of the answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://gotoes.org/sales/KenmoreManual.htm
Thanks
Tim
Oct 12, 2010 | Vacuums
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
Need the manual for Ultralux U160A Vacuum by Electrolux
You should be able to order a user's manual through an Aerus Electrolux store ( http://www.aerushome.com/storelocator/ .) They will of course try to sell you a new vacuum. To the best of my knowledge, the U160A was built by Aerus for sale exclusively on QVC. The Aerus/Electrolux stores never sold them and they probably don't like them because of that. They will likely say that they don't "stock" parts for the U160A. That's too bad. It was made by Aerus and tell them you want the manual ordered. I don't know what it will cost.
Sep 07, 2010 | Vacuums
Kenmore cannister vacuum model 116.2411290 has begun exhausting a 'burned' smell. Suspect bad blower bearing. How to access?(Can't find manual online.)
Hi,how are you so sure the problem is from the blower bearing and not the belt,well to know if the problem is from the blower bearing or the belt you have to know how to access your vacuum first,so from all angle you need the manual You can download the manual of your kenmore cannister vacuum from this website;www.manualsonline.com.I found it there Thanks and take care
Apr 01, 2010 | Kenmore Vacuums
I need a manual for my kirby vaccum , its making a high pitch noise
A manual won't help you on this one. You have a bad bearing behind the impeller. Ther squeal at first and scream as they get worse. DO NOT OIL IT. That will only attract more grit into it.
Mar 05, 2010 | Kirby Heritage II Vacuum
The brush doesn't rotate on the turbo tool. the belt on it isn't broken it just seems really stiff to turn by hand as well
The belt doesn't have to be broken to be bad. Even if it is stretched or worn it will not turn the brush roll properly. Here is the belt you need and the manual which has instructions:
Dirt Devil Vision Turbo Belts
Download the Manual (PDF)
Dec 21, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Cant get any water to floor or hand dispenser on my bissell power pro steam cleaner
That means that the pump belt is worn or stretched and needs to be replaced. Here is a link to the belt you need and the manual which has instructions:
Bissell ProHeat Belt and Manual
Dec 12, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Kirby G4 Bagged Upright Vacuum Logo
256 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
