The electricity went of for couple of hours and now we have no channels at all. it shows on screen TUTV-110PPV-8303-0115c-0194.
    Genius:
  • 1,067 Answers
Can u do a auto scan again in tv menu
Posted on Jan 23, 2008
Error 0194 ibm think centre 8185 desktop
Try going into the Bios or System Setup and see if there are some settings for System Security or Asset ID Antenna. It sounds like something is set in the Bios. Turn the computer off, then turn it back on and watch the screen for which key it says to hit to get into the Bios or System Setup. Hit the key when you see the message or it will not work and you will have to reboot and try again.
May 29, 2012 | IBM Thinkcentre 8185 PC Desktop
I have samsung lcd tv LA32B. A couple months ago, the tv worked well. Then something went wrong. I had to wait 5 minutes to see channels appeared in the screen. A month ago, my tv could not display all...
try the flashlight screen test with TV on to be sure an image is showing, hold flashlight above at an angle, if you see a faint image the motherboard needs replacing
Oct 30, 2017 | Samsung Televison & Video
How do i programm 735 t6 timer prince castle timers
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Oct 08, 2010 | Prince Castle 740T2 2Channel Single...
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
2005 Highlander Rear Power Window off track
you may need service. generally, if a window pops off it's track, it's more than some DIYers can handle. if you manage to get the window in the "up" position, and the higlander uses a tailgate-style access to the rear, you lose that access. toyota windows are notorious for popping off their tracks.
Jun 11, 2009 | 2006 Toyota Highlander
My Sony Trinitron only turn on when After 5 and up hours..
1. Your TV has a weak picture tube, the beam current detection circuit muted the video, you may rejuvenate the CRT, or turn up screen control (located on the fly back transformer) a little it may help.
2. Other thing is that to check out is there any dry-out electrolytic capacitors in the main power supply circuit.
Jan 15, 2018 | Sony Televison & Video
Got no instructions
1-The TV needs to be on channel 3.
2-On VCR remote set VHS/TV switch to VHS. (click it a couple of times until VCR channel shows on screen)
Dec 25, 2008 | Televison & Video
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Picture but no sound
have u tried to unplug it maybe an hour.then plug it again..this is basic reseting the unit.thanks ...hope this help..
Dec 31, 2007 | RCA TruFlat 27F520T 27" TV
294 people viewed this question
 Grubhead
Grubhead
