Question about Refrigerators
Kenmore Ice maker
Replaced Kenmore side-by-side ice maker. How long before it starts making ice? An hour later and it still hasn't filled with water.
  • 63 Answers
It should have made at least one batch of ice by now. Make sure the water is on to the ice maker. Also the water line should have the air bleed out of it. It might have opened the solenoid valve and only got air.
Posted on Jan 28, 2008
3 Suggested Answers
  • 1314 Answers
SOURCE: Kenmore
sounds like your freezer isn't freezing lift up the wire arm on the ice maker to shut it off then put your finger where the ice cubes should be and if the water isn't frozen you may have a cooling problem listen to see if you hear the freezer fan running then look at the bottom of the freezer at the back wall where the vents are and see if they are blocked with frost and reply to me
Posted on Dec 31, 2007
  • 415 Answers
SOURCE: i have a kenmore side by side refigator and with
sounds like the watervalve is failing and also most likely the shutoff to the waterline for the frig is plugged or not allowing the water to flow properly then try jto shutoff the saddlevalve and open it all the way again then try the water again if no results replace the waterline shut off min in cost at locations like menards they are 6.00 and less and are the type you have to drill a 1/4'' hole and install also it you are have the ability if water still not flow then replace the valve at the rear of the frig
Posted on Jan 01, 2010
Kenmore WR30X0318 Ice Maker Stopped Making Ice
The ice maker uses a internal thermostat that starts the cycle of dropping the ice and refilling with tap water. If your water control valve works filling the ice maker then the problem is the ice maker itself that will need replaced. Unfortuantly the ice maker you have has no rebuildable parts and will need to be replace with a=> WR30X10093 Ice Maker Assembly
Or here=> WR30X10093 Ice Maker Let me know if you have questions, Thanks Sea Breeze
Nov 14, 2012 | Kenmore Refrigerators
The ice machine stopped working. You can't hear the water run in the ice machine. I replaced the water filter.
fill the Ice Maker with a 1/4 cup of water using a turkey baister. wait 2 hours and see what happens.
Sep 03, 2012 | Kenmore Side by Side Refrigerator
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Ice maker very slow to make ice
there may be some thing stuck in the ice machine try checking it out
Jun 02, 2009 | LG LSC26905TT Side by Side Refrigerator
Ice maker repair and still no ice
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser . The valve that the ice-maker relies on may be bad,
  • or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
btw- you can replace the whole icemaker system for around  $115.00.
  • charging you $250 for a $20 drive motor is ridiculous! my 12 year old son can change the drive motor in 15 minutes.
Jul 06, 2008 | Refrigerators
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore
Dec 31, 2007 | Refrigerators
Amyc, of course you should call this cat back, but here are a few things to check. Make sure that the fill tube is not frozen over. The black tube feeding water to the IM. Next with the freezer door open your optics should flash twice with a pause repeatedly. Hold the left side emitter flap down and the light should be on steady. If this checks, the optics are good. The ice maker rakes should be at the 2:00 position when it's in it's home positon. Any other position could be a bad module. When the cat comes back to check it out, make sure he jumps the ice-maker to get the unit to fill before he leaves...Catriver..post back.
Mar 02, 2007 | Kenmore 53582 / 53584 Side by Side...
Refrigerators Logo
396 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
