Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Wireless Signal drops to 24 on 54 G Verizon router and then nothing works
This is a Verizon Fios Router. In my home I have tried to use the wireless on this router but it would always drop to 24 speed even though the signal was full bars. When this happens everything stops. No email..no webpages. So I tried turning off the wireless and connecting a Linksys 54G router and using the router on it. I still use the DHCP on the Actiontech though. Again it connects at 54/full bars but after a while it will degrade to 24 and then nothing happens again. I have tried two different routers with the same results. This seems to indicate that the problem is either with the Actiontech or my Fios. I have the same results on four different laptops. All different models, different wireless devices. Again, seems to point at the Router or Verizon. Verizon is no help. Distance from the router makes no difference. I can be 5 feet away with no obstructions and get the same problem. Currently my solution is that I have two Linksys Routers connected to the ports on the Actiontech. They are located about 15 apart up on top of bookshelfs neare the geographical center of my home on the first floor. When the speed drops on one, I connect to the other, and badda bing I am back up to 54...for a while. All laptos are running XP SP2 and use the windows wireless configurator.
I have been trying to figure this one out for about 6 moths so any help you can offere would be appreciated.
I have had similar problems with my FIOS/Actiontec wireless network.
I was instructed to upgrade the firmware on the router, which you can do by logging into the device, going to the advanced tab,and following hte instruction.
This helped some.
But lately the problem is back.
Posted on Feb 01, 2008
I have the same problem
Posted on Jan 24, 2008
6ya staff
SOURCE:
Wireless network very slow. We are fine when hard wired into the router but when not it's painfully slow. We have a Verizon fios wireless router westell 9100
Make sure you are connected to your network on wireless and neighbor's
open a browser and go on to www.speedtest.net
click to check your internet speed Fios is pretty fast!
Your wireless if connected to your own network the speed is comparable weather wired or wireless!
Try these steps and let us know the results to further help you!
good luck
Sep 11, 2011 | Computers & Internet
Am using verizon fios wireless router 9100em but would like to add my linksys wrt54g for all wireless functions. Both routers use 192.168.1.1 to access router menus I can access the verizon but can't get...
You will need to change the dafault ip of one of the device.
Connect using a calbe lan first browse the ip 192.168.1.1
then change one of the device 192.168.1.2
Then set one as (ap repeater) access point router..
ok try this
Jun 30, 2010 | Linksys Wireless-G WRT54GS Router...
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Different router and extender signals
you are seeing your neighbours wireless as well. hook up to the one that is your router/provider
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
I suspect that Verizon is degrading service to forcr users to mig
Anything is possible but it would take a lot of work to jam wireless signals. As a communications company, Verizon, if caught would be in hot water with the FCC. I have an idea. Are you able to change channels on your wireless and try it. Also, is there anyway you could try a different wireless router? If FIOS is coming in, there may be maintenance changes in the infrastructure that effect your internet performance.
Aug 14, 2009 | Westell Wirespeed VersaLink...
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Cisco vpn will not work with verizon service now after we got a new modem through verizon
Verizon Home DSL service uses a special filter that prevents ALL incomming connection including web, email and VPN hosting from a home connection. Business internet does not limit this, and I don't believe FIOS blocks it. If you have verizon home, there's nothing you can do. If you're just trying to connect to a home machine, you can try something like gotomypc, or a free alternative like teamviewer.com or logmein.com.
If you don't have verizon home dsl, comment back with what service you do have, and we can try some other things.
Steven
Jul 24, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Dropping wireless connection
The problem may not be with your router. I had a situation a year ago with the modem dropping the signal everyday. I spent hours on the phone with verizon tech support to no avail. They sent someone out to my home and he put a filter on the main line coming into the house which didn't resolve the issue. Then verizon insisted the modem was bad so they sent me an actiontec. Turns out that the problem had nothing to do with me. They try to squeeze as much bandwith at their switching stations as they can. They switched me over to another hub and viola no more problem.
May 20, 2008 | Actiontec GT704WG Wireless Router...
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
288 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Ekse
Joaquim Martins
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
