Question about Ricoh 3310Le Fax Machine, FAX3310Le Printer
PCU? fax\printer machine says time to change this something I can fix myself or does machine need serviced?
  • 417 Answers
Hi the you will be able to purchase the PCU (Photo Conductor Unit) it is customer changeable so type in the following in google there you will be able to find a store that sells them.
Photoconductor unit for ricoh 3310
Thanks J
Posted on Jan 28, 2008
What does time to change pcu mean?
Hi, PCU stands for photo conductor unit, most of us call it a drum unit. You should be able to order from any office supply. It is easy to install and will come with directions.
Oct 08, 2014 | Ricoh 3320L Laser Fax
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Hi.when i m switch on the Ricoh 3310L Fax,the message is coming as shown below "time to change PCU"
Order a new PCU from Ricoh. Power off the machine and replace the pcu.
If you try and cheat it it will run for a short while and then lock-up breaking some gears. Cheeper just to order a pcu. Check Ebay, i see alot of Ricoh supplies there.
Jan 23, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Fax shows ''time to change PCU'' how can this be fixed?
you need to replace the Photo Conductor unit (drum unit).
Nov 17, 2009 | Ricoh 3310LE Plain Paper Laser Fax
Time to change PCU- Ricoh 3310L
Go to this page and find the official ricoh service department for your area
Nov 07, 2008 | Ricoh 3310Le Fax Machine, FAX3310Le...
Time to change PCU
You just have to press the "yes" button. Watch the display. It says "Change PCU Y/N"
Mar 26, 2008 | Office Equipment & Supplies
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Oct 15, 2007 | Ricoh CL3000E Laser Printer
Ricoh 3310L Fax machine - 'Time to change PCU'
You need a new drum. Photoconducter unit. Cost about 140.00 I sell them or you can shop on EBAY
Aug 10, 2007 | Ricoh 3310Le Fax Machine, FAX3310Le...
1,369 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
