Question about AudioBahn DUB Mag Audio DUB4001 Car Audio Amplifier
I have a dub 4001 amp
I was driveing down the road and my amp stoped working and when i got home the amp light wutch is green is now red and wont go back to green
  • thizzcore Feb 20, 2008
    so i have this problem to and i changed my ground and now my amp fully works. blue lights fan and all but my subs still have no sound.
  • Anonymous Aug 18, 2008
    i hooked everything up properly (i think). the red light still comes on.its properly grounded and the 12 volt and remote wire are hooked up fine. any suggestions on what i should try?
Turn it on unplug a speaker wire let the light turn gren then plug it back in to trick it it works I have the same amp and matching subs if you get it set up right it will pound I like it
Posted on Feb 05, 2011
I have the same amp and the same was under warenty once so i tokk it back they sent it away to get fiexed and all they did was say it works perfectly fine nothing wrong and that i was using a 2ohm sub instead of a 4ohm which i i went out of the shop to my car plugged it all in and no go.took it back into the shop and got the guy to plug it inot his demo units and it still didnt work.he called the repaid centre in which he had no luck so he just gave me a new amp to replace has now done the same thing but is out of goes into protection mode and locks itself their.
Posted on Aug 07, 2008
Me to i've got 4001 DUB amp in my car its so **** man, not like kenwood or pioneer my 1200W kenwood sub disconnected from time to time and return to factory bass, and the amo gets very hot
Posted on Aug 06, 2008
  • 65 Answers
Take it step wise.
Unplug the inputs and outputs from the amp (be sure to mark the wires so you can hook them back up), leaving only the ground, +12, and remote wire hooked up. Now, turn it on. If the amp light goes red, the amp is broken. If it goes green, turn if off, plug in the speakers, then turn it on. if it's red, its a speaker problem, if green, do the same with the inputs, and you'll have your answer.
Posted on Jan 23, 2008
Check with a code reader or scanner, the ABS could be at fault
Mar 24, 2013 | 2005 Nissan Frontier
Securty problem truck wont start 2001 gmc searra died out driving
You have a fualty electrical condition,This can stem from a broken insulation wire to poor connection or the insulation that has rub through.The problem you have plaque GM. No need to by pass just get to the ignition area inspect the harness if anything you have a bad connection
Mar 12, 2012 | GMC Cars & Trucks
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Converter wont work red light on when i use the remote it wont turn green when i push the red button manualy it still wont turn green
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
Aug 05, 2010 | Apex Digital HT-150 System
Dub 2502 not in protect mode but not putting out
i dnt knowwat type of speaks u got but ifits low then it cud be tht u have too open up the second coil on ur speakers...dnt sound like the amp since its on & not in protect mode,other than tht i'll recheck the wiring
Apr 07, 2009 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Problem with my amp
the proble could be that the negative cable is not touching ground, or that the remote is not tide enough.
Mar 13, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Amp stuck in protection mode.
check to make sure your ground wire is attached to a clean metal surface no more then 18" away from amp. check all wires to ensure none are touching other terminal. all else fails remove one sub and see how it play, if its works great switch subs. could be a defective amp. if it is the amp and you payed for it with a credit card or bank card you can do a charge back from the bank to get your money back if the store wont replace it. thell the bank "you want to do a charge back cause it wasnt as discribed).
Nov 10, 2007 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Car Audio & Video Logo
635 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Nicholas Csorba Jr.
Colin Stickland
Colin Stickland
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
