Question about Mitsubishi WS-55809 55" Rear Projection Television
Television too big to fit up stairs is there a way to seperate the televison
I know it sounds stupid but I had the same problem. Took the wheels off the bottom and it fit by 1/8 of an inch. Then just put them back on when you get it up.
Posted on Jan 30, 2008
    Sergeant:
  • 226 Answers
Wow. if i were you dont try to separate the tv from the casing it might have built in components that youll be messing up can cause damage to your tv.
pls rate me.
Posted on Jan 22, 2008
Hip surgery getting down and up stairs
you can rent a stairlift. stairs are the main reason people have accidents after hip surgery. Be very careful. Maybe get a double railing or something if you havent the money for a rental.
Jan 11, 2018 | Exercise & Fitness
This tv is to big to fit through the door so how do i remove it from the base?
you can unscrew the large back plastic section to make the tv a bit narrower...but be careful as this is the piece the mirror is mounted to on the other side...just make sure you have someone help you do it.
Feb 28, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Can't pick up channels itv, channel4/5 and itv2 on my bedroom freeview tv and down stairs doesn't pick up film4 and a few others?? I have only recently connected the bedroom aerial to the ariel which was...
hi when fitting an new aerial line you need to put a splitter in the line.
4963215_1-oo4k03phwtyaxld0gomgkgbv-2-0.jpg it looks like this. they say satellite/tv on them this will stop interference from the boosters and the tvs on the same line, you connect it on the main arial line. you can then use both boosters if signal is weak but most digital aerials are good enough without them. it you have the right arial for your area. there are meany sizes. but say you are 15 miles from your tower then use a small aerial has the same fitting as this pic. that is out side aerials, inside aerials ie in loft you need a high gain aerial , long type. hope this helps. also if the aerial is not lined up it will not get great signal there is an app you can use on iphone or androids, tables etc to help you position the aerial in the right place it's called Uk aerial alignment . tool on app shows you the towers in your area and the best ones to use and shows you the aliment to the tower for best results. good luck
Jun 22, 2017 | Samsung LE40R74BDX 40 in. LCD Television
My big screen tv is about 3 inches to big to take down my stairs into my basement. Can it be dissasembled? Are there any sketches on how to dissasemble the speakers? Thanks Don
Yes but it would be easier to widen the stairs and just moving them can stop them from working so if you decide to take it apart just be careful, Manuals are available online but non are free
Dec 02, 2010 | Samsung HLT6187SAX 61" DLP HDTV
Need to know if TV can be separted into 2 pieces
Yes it can and does come apart in 2 fairly equal sized pieces. There are some screws on the sides when removed the top half with the mirror will lift off. It may require some extra force the first time it is done but comes apart with ease after that
Feb 25, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Panasonic pt-51hx40b
big screen tvs are not made to come apart that way.the only thing you can do is take the back off it and i dont think thats going to help your situation
Dec 06, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Moved, now can't get the TV downstairs
it went down the stairs in one piece it should come up the same way
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WS-55809 55" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
