Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire Affinity After the wash cycle is copmlete it will turn slowly one direction and then slowly the other and then shut off. It dosn't give any error message and the clothesare not spun out. Checked the belt and it is not broken or slipping, the pump does run for a bit and then it shuts off. The drain lines are also clear.
  • Anonymous Jan 26, 2008
    same problem with my machine. We have also cleaned out the filter.
I SAY REPLACE TIMER CONTROL BOARD
Posted on Jan 31, 2008
6ya staff
SOURCE:
Why some on my cycles wont work nor my light s will light up on my affinity to load washer
Good Afternoon Friend,
I understand that some of the cycles will not work on your Frigidaire Affinity washer, model# ATF7000E. I also see that the lights won't light up either. I suggest giving your appliance a hard reset, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. After restoring power start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire Affinity ATF7000E Front Load...
E pa au u5 5e
Good Morning Friend,
I understand that you are receiving multiple error codes on your Frigidaire Affinity washer, model# FAHE4044MW. I see that the error codes showing are "E", "PA", "AU", "U5", and "5E". I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
WP
May 15, 2014 | Frigidaire Affinity FAHE4044MW 27"...
Affinity washer wont work on a normal cycle only delicate
looks like the windings on motor are burnt out , motor has different winding for different cycles
Mar 20, 2012 | Frigidaire Affinity ATF7000E Front Load...
When i turn on my frigidaire affinity front load washer it beeps and LOC comes on the screen it will not do any thing I have unplugged for a while it still says samething with the door open or closed ....
The control lock feature has been activated. To toggle this off, press and hold Options and Select for 10+ seconds. There is a small padlock indicated in the middle of a line between the buttons that toggle the lock on and off. This feature prevents anyone from changing a wash program when in use or a child starting a cycle with the cat or another child in the washer.
The manual for most Frigidaire appliances are available here: http://www.frigidaire.com/manuals . Enter the model number and click Search. Frigidaire lists several models of the Affinity ATF7000E. The direct link to the operating instructions manual for the ATF7000ES0 is here: http://manuals.frigidaire.com/prodinfo_pdf/Webster/134602700ef.pdf . In this manual, the control lock is described on page 2.
I hope this helps.
Oct 30, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF8000FS gives me an error code of E48. Stops a few mins after cycle begins
I have the same code and problem...E48:Board thinks the PTC circuit is closed. Any help?
Jul 24, 2010 | Frigidaire Affinity ATF8000FS
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity front load washer will not spin
sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
Dec 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
164 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
