Question about Cadco OV-400 Electric Single Oven
Grinding noise every now and then
After the oven is turned on there is a sound coming from the back, kind of like somethin something is loose or rubbing. We have opened it up and looked at it and it seems fine. Could it be the motor on one of the fans?
  • 196 Answers
If this is a self-cleaning model it is possible that the movement of the mechanical parts are at fault. Toward the back you should be able to find the motor and drive rod. Check these first and yes, there could be a loose or faulty fan motor.
How long is the sound there ?
Posted on Jan 26, 2008
Cooling fan makes a rattle noisy when the oven gets hot & after turning the oven off. Very very annoying.
I would suggest taking a look at the fan and seeing if any hardware has come loose. A loose holding screw will cause the fan to wobble in its cage and make noise like the one you're describing. If all the hardware is tight, try a dab of WD40 to get everything moving properly.
May 23, 2015 | Ovens
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
Main oven motor cover
Why not secure the fan cover?
Jun 22, 2013 | Ovens
My electric Oven keeps tripping the breaker off as well as making a popping noise while doing it and leaving a burning smell. When i turn the knobs to the burner on i hear a clicking noise coming from the...
Hi. YES you most definately have a short. The burning smell is coming from either the wire arcing and thus producing ozone and heat, or the insulation on the wire is being burnt. Take the back off the control unit to expose the wires and see if you can see where the wiring is burnt. It could be a loose connection, or something more serious.
If in doubt, call a professional repairman to check it out.
Earl Marshall
Norse Tool/Equipment Repairs
Sep 22, 2011 | GE JKP15 Electric Single Oven
Seems like the blower motor is making a lot of grinding noise and the fan is not spinning quickly. also the fan continues to spin when the door is open.
the blower wheel has come loose from it's base, this happens a lot with ovens where aluminium foil is used, as the Moffat oven was designed to be the ultimate pastry oven, free flow air system was designed into it, I would start with the blower wheel as it is usually the cheaper of the 2 to buy.
May 24, 2011 | Moffat Ovens
Fan noise
It is a cooling fan, and, yes it can be replaced.
Please rate my solution.
Nov 22, 2009 | GE Ovens
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Redhead Do nothing and call the manufacturer. Your oven has one year warranty. back
Mar 22, 2007 | KitchenAid Architect Series KEBC278KSS...
Cadco OV-400 Electric Single Oven Logo
111 people viewed this question
Top Cadco Ovens Experts
Dan Webster
Dan Webster
Are you a Cadco Oven Expert? Answer questions, earn points and help others
