Question about Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television
Power light flashes and then goes red.
The power light flashes and then goes red. I relaced the lamp and I still have the same problem.
  • chucksproper Jun 24, 2008
    The set comes on fine as normal for about a minute. It the shuts down on its own, the power light flahes along with the lamp light for quite a long time. Is there really a problem with the lamp as the idiot light is indicating? Or something else. I haven't replaced the lamp as it is not "burned out". Is this a normal lamp failure?
Most likely convergent amp went out... Mine did the same.. Its a 30 dollar part but unless you know wht you are doing.. Repair places will gouge you for 600 in labor... Best of luck...
Posted on Jan 22, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Hi i have a kdf e50 a12u the bulb went so i relaced it and still no picture just keeps flashing green and red any ideas?
Ballast board it is what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
You need to make sure you do not have any defective Cooling Fans -If Lamp Fan is Defective Lamp will not come on either.But if Fan is running and Lamp Fails to light Ballast board
Sep 30, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
No picture
When you turn it on if you haer a high chirp chip befor the light turns red
starter ok lamp has reach its life needs to be replcce
Mar 04, 2008 | Canon LV-7210 Multimedia Projector
Panasonic PT-60LCX63 60" Rear Projection HDTV-Ready Television Logo
327 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
