Question about Mitsubishi WS-55711 55" Rear Projection Television
Have sound but no picture at all... not even the channel indicator or only visual using the TV remote. Don't projection tv's have 3 bulbs (blue/green/red)? if one burns out, wouldn;t the other two still work? Any ideas. Bought the TV from Tweeter but their 800 repair service has not bee responsive. Daner
  • Daner49 Jan 22, 2008
    Slinteriors
    My trouble shooting and soldering skills for this type device are inadequate. Just learned that the set is still under warranty until Sept 2008. Bought it in 2003... looks like service contract was good investment!!!!!! Thanks for your response and I really appreciate your fast feedback.
    Daner
  • Mitsubishi Master
  • 8,617 Answers
Its definitely not the CRTs. More likely a problem in your deflection circuit Horizontal or vertical. Could be the vertical output as well. your not getting deflection if you don't have any menu or channel indicator.How are your trouble shooting and soldering skills?Let me know if I can help you further.
Posted on Jan 22, 2008
  • Sonny Berry
    Sonny Berry Jan 22, 2008
    Good to hear your still under warranty. Thats one of the good points about extended warranties.
How to fix Samsung HL72A650C1FXZA DLP TV with no sound, no picture, bright screen with lamp light flashing?
Check the bulb ballast board. It's the board that the wires from the bulb connect to. That is most likely causing the Sounds like the main board is the culprit for most of the problem. The picture problem can be the color wheel not turning. The lenses in front of the bulb should be taken out and cleaned too.
Oct 12, 2016 | Samsung Televison & Video
When i turns off video for to get the channel 3 back aucan signal comes up how would i get back to the channel 3 to watch tv
If your DISH remote is programmed to operate your TV, you can press the TV button at the top of the remote and release it. On the number pad, press the number 3. If you get a picture, press the SAT button on release it. You can now operate your satellite receiver.
If you don't get a picture, use the TV remote to place the TV on channel 3 or you can use the channel button on your TV.
Aug 06, 2011 | DISH Network 625 Duo DVR Receiver...
I have a Panasonic PT-51630T CRT projection TV, 50" screen. It was manufactured in 1995. I had picked it up from our town clean-up (people come to throw away trash and old stuff they don't need or...
CRTS tubes projection tv,don't have a projection bulb.Only have 3 CRTS tubes guns like R,G,B crts tubes.The tv have picture a couple hours than dies and have a high pitch sound,that mean the tv have a bad and dying or a cold soldering to the (FBT- the flyback transformer),the tv have a high voltages problems,the FBT that the big block of a plastic with a wire hook up to a to a board.U have tools like a soldering iron,a roll of solders and a roll of desoldering braid,can u also do basic soldering work?Yes resoldering all the FBT connections and the wire connected to the board and all the parts around it.Still have the same problems after that,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a refurbish FBT for the replacement.
May 04, 2011 | Panasonic Televison & Video
A brief history: fixya helped me change my bulb (been receiving a "replace bulb" message for awhile until my picture went black). The picture now is snow, not black which seems to me to indicate the bulb...
Since you do have sound but snow for picture is your TV 54J or 54U chassis the PT50DL54J chassis shows 4 tuners also Have you look for Leaky or Bad capacitors if they are puffed up on top they are Bad 2200uf 25v 1000uf 25v Look for bad capacitors on tuner Boards, and I have seen where they are on Power supply board that will affect Picture.
Dec 04, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
No picture
make sure the tv is in the correct input, either tuner channel 3 or an a/v input
Dec 16, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Help me willtab guru man...Please.
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says otherwise..im not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Jun 16, 2008 | Televison & Video
Same problem as this poster
i had a similar problem and it ended up being the bulb. The indicator light never lit up but after i replaced th bulb I checked to see how many hours where on the bulb and it was over 8100. they state the bulbs are only good for 6000. when i replaced it ($140 on ebay) everything was fine.
Sep 09, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WS-55711 55" Rear Projection Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
