Question about Sony VGN-S150 MBX109 (M9_32 (A1072469A) PC Notebook
UPGRADING PROCESOR NEED INSTRUCTIONS FOR REPLACING (UPGRADING ) PROCESOR
  • 593 Answers
Make sure your BIOS can handle an upgraded CPU. I would go into bios, check the "default" or "fail safe" boot option and then power down. Lift keyboard or access your CPU and change out. Remember to touch something metallic before you operate so you discharge any static electricity (killed a CPU and a video card by not doing this ONCE) Boot up and notice any BIOS messages, may want to start in safe mode just to get a basic working config going, then power down, access BIOS and start getting it back to your best config, maybe stepping one item at a time, rebooting and continuing until you get a stable platform.
Posted on Jan 22, 2008
LG LCD TV has yellowish center tint
A firm ware upgrade might solve this problem. Upgrading your RAM, if not, the procesor ic on the main board.
Nov 01, 2011 | LG 42LH40 LCD TV
Chang procesor iwant update bios hp dc7100
These are rather advance things you are asking for. If you are sure you know what you're doing, I'll provide links for you at the end of this, if you are unsure of what you're doing, do not do anything yourself, but instead take it to a store to replace and/or work with.
To change your processor you can follow this video
The bios of a motherboard is built in, you'll need soldering skills to replace or upgrade that,
http://www.hardwaresecrets.com/article/How-to-Perform-a-BIOS-Upgrade/33
Jul 17, 2011 | HP Compaq dc7100 PC Desktop
I want to upgrade my procesor to faster procesor.
Upgrading processor is not likely a practical solution; find out the motherboard manufacturer and contact their site for more information. As to upgrading the motherboard, you'll have to know what kind/size of board your system will require. If you don't have lots of experience, this process is very risky.
Frankly, the cheapest way to upgrade your computer is to buy a used and working product with Windows XP already installed. Go to http://craigslist.com, select your city, and search for a brand name you trust. I've bought DOZENS of used computers very cheap that way (I'm writing this on a $2,200 Dell Latitude D620 I bought fiv months old for $500, who needed the cash!)
Mar 30, 2009 | Gateway Computers & Internet
Upgrade question on ASUS P5GD1-VM/S mobo
According to the manufacturer it will support P4/celeron 3.6Gz+ procesors. And memory should be Dual channel memory architecture 4 x 184-pin DIMM sockets support max. 4GB DDR 400/333 non-ECC memory. Hope this gets you up and running.
Jan 31, 2009 | ASUS P5GD1-VM Motherboard
I hv my asus p4s533-mx with a 1.5ghz procesor.
If you are using Windows XP or Vista you need more RAM to correct this problem. Try upgrading RAM to at least 1 GB. Hope this helps.
Dec 22, 2008 | ASUS P4S533-MX Motherboard
Dell keeps shutting down
Check the procesor fan, if it come loose the temperature rises and the computer shot down to protect the procesor..or probably the procesor lost the heat sink compound.That is a compound that comes over the back part of the procesor and help the procesor to transfer the heat to the heat sink of the procesor,The heat sink is that metallic piece that you see under the fan of the procesor..probably you need to put a cap of that heat sink compound..you can get it in any electronic shop that sales repair parts for technicians.
Jul 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
CHIP UPGRADE
Hello there.
As per here , the largest cpu supported is the 1.4GHz Pentium 3.
Hope this helps.
Jul 07, 2008 | Gigabyte GA-6WMM7 Motherboard
HP Vectra has no fan hook up!
Most fans are either 5v or 12v and have a hook up on the motherboard. If not the fan should have a + and a - side (normaly red is + and black is - ). If push comes to shove use the same voltage lines off a hard drive power connector on the power supply if the motherboard doesn;t have the connector built in.
Apr 20, 2008 | Computers & Internet
Upgrade my computer procesor
Socket type: mPGA478 (P4).
P4 – 1.4-3.4 GHz
P4 EE 3.2-3.4 GHz
MOTHERBOARD MANUAL: http://www.elhvb.com/mboards/OEM/HP/manual/danube_manual.pdf
It shows you how to take off and put in the CPU.
This is a guide on how to install the CPU/with FAN.
http://www.pctechguide.com/tutorials/Pentium4_CPU.htm
Nov 11, 2007 | ASUS P4B266 Motherboard
Can I use Athlon X2 procesor with this mother board?
It takes Socket-939 processors (AMD Athlon 64/Athlon 64 FX [K8]).
X2 processor used Socket-AM2
Nov 11, 2007 | PC Chips A21G Motherboard
Computers & Internet Logo
119 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
