Question about NetGear WGT624 Wireless Router
I have a netgear wgt624v2 and i can't get to connect to wi-fi on my ds
I can get my ssid to load but then then i test connection and it dont work. i looked on the website and it says you need the wep key
    Problem Solver:
  • 16 Answers
You are having problems with your encryption settings.
Remove the old settings from your operating system.
After this look for wireless connections.
Then click on your network.
Your operating system will now ask for the security key. Enter your keyword and connect. If web is the only problem then everything must work now.
Greetings,
Pascal
Posted on Jan 23, 2008
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
May 25, 2016 | NetGear WNR2000 Wireless Router
Where do i go to get a wifi conection
To conect to wifi, you'd need to buy a WI-FI USB connecter. They can be found at most video game stores for $37.00 (varies on location) They get plugged into your USB port on your computer, then they enable you to connect to wifi . If you have a Laptop the USB port should be found on the side.
If you just need more information off of what I've given you, read the bottom of my post for a recommended website for Wi-Fi.
When you get a USB connecter:
On your DS:
Once you have it plugged in, turn on your DS with a game that is compatible with Wi-Fi. In the game there should be a place where it allows you to adjust your Wi-Fi settings.
When you select that, two options should appear, tap on the one that is labled "Nintendo Wi-Fi Connection Settings" You'll see four options to chose from, you want to tap on the one near the bottom of the screen, it's shown as "Connect To Your Wi-Fi USB Connecter." The next screen will say for you to install your Wi-Fi connecter software to your computer
On your computer:(you must have internet connection on the computer)
Close your DS for now and turn your attention to your computer, insert the USB into the the USB port on your computer. The picture that is next to the port will look like this:
Install the software first, then a window will appear after the installation. Ignore it for now, and look back to your DS.
On your DS:
It should still be on the same screen you left it on unless your battery is dead (not recommended to conect to wi-fi with low power )
Tap "Ok" on your DS, It'll then launch a test connection. Look back at your computer screen now.
On your computer:
The box I told you to leave alone before will still be on, and now it should have your DS name inside it. Your DS name is what you entered your name as on your DS configuration settings.
Click on your DS name and select the option allow access. You can either allow or deny anyone access to connect on wi-fi through your USB.
On your DS:
Now that you have allowed access to your self on the computer, you can get back to your game and tap on "connect to Wi-Fi" this time instead of tapping "test connection." You'll then get a friend code that will allow you to interact with others who have connected with the same game.
Notes: For more about getting started,connected, and swapping friend codes, view this site: http://www.nintendowifi.com/global/AboutWIFI_DS.jsp
Also, if you've ever heard of a Wi-Fi hotspot, that just means you have to take your own computer or laptop with Your own Wi-Fi USB connecter to the certain area for free Internet service. This only means public areas, like at Starbucks or Panera Bread Compay, but then if you're doing this at a friends house then you just need to get your self registered access on their USB.
Aug 18, 2013 | Nintendo DS Lite Console
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
How do you get the wi-fi on the ds
To set up a Wi-Fi connection on your DS Lite you have to use a Wi-Fi enable DS game. Wi-Fi enable DS games have a Wi-Fi symbol on the front of the box it came in. Simply play the game and you should see options to set up a Wi-Fi connection.
Apr 21, 2011 | Nintendo DS Lite Console
What is the "SSID" and
Welcome to Fixya. The SSID is the name of the network or network name. I have the guide below on how to connect your DS to the internet and how to obtain the SSID of the network.
How to connect DS Wirelessly Guide
If you have questions please let me know. Thanks for using Fixya
Apr 09, 2011 | Nintendo Video Game Consoles & Games
Nintend wi-fi-connection
Welcome to Fixya. Nintendo Dsi/DS/Ds XL connects to the internet using wireless connection. You need to know the settings of your router. I've listed below the steps on how you will access the router and to obtain the information needed for you to be connected.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and theNetwork Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection.
Thanks
Mar 07, 2011 | Nintendo DS Lite Console
I dont know how to connect to wi-fi
Welcome to Fixya. Nintendo Dsi/DS/Ds XL connects using wireless connection. You need to know the settings of your router. I've listed below the steps on how you will access the router and to obtain the information needed for you to be connected.
Feb 12, 2011 | Nintendo DSi Black Console
My ds lite cant connect to my netgear WGR614because it says its security settings are not supported by the ds
Hi eporre1,
If you're receiving that error message we need to access the Wireless Settings Page of your Router to change some settings. Keep in mind that if we change the settings of your wireless connection other machine that is connected to the network will be disconnected due to the new settings, so take note of the settings that we will be changing.
To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Settings Page try changing the encryprion to WEP 64bit and generate a Network Key. Remember the network key so that if you have laptops that are connected and will lose the connection that is the password that you need to input. If WEP 64bit wont work try WEP 128bit or WPA you can also disable the Security however you network can be access by others.
4. Test the Connection. If you have questions put a comment here.
Rate me if this helps so I can hep others. Thanks for using Fixya.
Feb 04, 2011 | NetGear WGR614 Wireless Router
My ds cant find my wi-fi adapter
dont worry ppl i fixed it, i found out that my internet connction that was going through the W-Fi adatper, wasnt accepting echo requests. but it works now.
Jun 12, 2009 | Nintendo DS Console
I can't get my DS and Wii to work on Wi-Fi with model 2701HG-B
turn up the power and change the wireless channel in the wireless settings
Aug 31, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
NetGear WGT624 Wireless Router Logo
59 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
