Question about Toshiba 50A50 50" Rear Projection Television
Toshiba 50a50 i had a power surge and now i get volume but no picture.the bulbs seem to b glowing dimly at the base so i believe power is getting to them but i dont know if there is any fuses or anything that might b the problem
  • Toshiba Master
  • 8,617 Answers
You have a problem in the deflection circuitry, thats why youre not getting any picture. Probalya blown line coil or transistor due to the surge. You may want to invest in aservice manual for your set If you have soldering skills you shouldbe able to track down the prblem and repair this set. You can get the manual for your set at the following link for 10.99 and they will email it to you if you requestfor them to do that for you. Here is the link. Hope this helps. let me know if I can help you further.
Posted on Jan 22, 2008
My Toshiba 50 A 50 rear projection has great sound but no picture. Can you help tell me if I need a fuse or bulb?
This TV does not use a bulb. It is a Picture tube type set.
*No picture but there is a dim background. Menu works.
This is caused by a bad signal. Perhaps the video cable is bad if you use a cable box. The HDMI cable may not be working right. Try a new cable.
*No picture, no menu
This could be caused by a failure in the part that draws the picture up and down (The vertical). Can also be the side to side (Horizontal) or a high voltage problem. The last usually kills the sound as well so its not as likely.
If the cable does not fix it, you will likely need a technician.
Mar 21, 2010 | Toshiba 50A50 50" Rear Projection...
No Picture on Toshiba 50A50
Check the fuse at F851 if open replace with 3.15 or 4 amp slow blow.
Hope this helps!
Aug 22, 2009 | Toshiba 50A50 50" Rear Projection...
Toshiba 50A50 whit no picture
cant understand what you going on about
Jun 04, 2009 | Toshiba 50A50 50" Rear Projection...
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
Toshiba TN61X81 took power hit
Sorry, but the short answer to your DIY question is "no". Good luck. . .
Mar 10, 2017 | Toshiba TN61X81 61" Rear Projection...
Toshiba 50A50
it could be high voltage cap located by flyback,if you have back off of tv2.gif and turn tv on,you will see green led's turn on,(on the board)if they turn off there is a small blue high voltage cap hidden under glue(i believe it's a 102 cap)that would be the one change,99% of time that is what will fix problem
Feb 22, 2008 | Toshiba 50A50 50" Rear Projection...
Hi,I have this same model Tv. The Remote control Model is CT-90037 You can pick it up often times on Ebay or Amazon. Hope that helps.
Sep 17, 2006 | Toshiba 50A50 50" Rear Projection...
Shuts Off
Theres a digital comb circuit that causes this symtom. Not a repair job for the amature.
Sep 02, 2006 | Toshiba 50A50 50" Rear Projection...
Toshiba 50A50 50" Rear Projection Television Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
