Question about Panasonic PV-GS2 Mini DV Digital Camcorder
0 characters
1 Points
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Sony handycam dcr-hc38 tape door wont close. fault code c:32:11
Try this if you are tech savy, if not you may want to take it to a person to have it fixed or send it off to sony.
1. unplug camcorder AC cord
2. remove fat battery from back of camcorder
3. remove slim battery from under the LCD (it's the size of a nickle coin)
4. wait 2 minutes
5. plug AC into the camcorder
6. flip the camcorder into VTR mode
7. tape should automatically eject
Found at :
May 31, 2011 | Sony Handycam DCR-HC38E Mini DV Camcorder
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
Sony Handycam CCD-TRV58 Hi-8 won't display picture.
This sounds like the LCD and CCT in the Lens is dead, not a cheap repair if this is the case, pop it to a camera shop like Jessops.
Jun 23, 2010 | Sony Handycam CCD-TRV58 Camcorder
Camcorder dead
Hi There, You probably have a blown fuse or 2. Either your battery or impact damage may have caused this. Unit needs to be serviced at a shop.
Thanks, mr cicmo
Dec 26, 2008 | Sony Handycam CCD-TRV37 Camcorder
If the display is defective we can supply it from Sony.
Check whether you can play the recorded images by connecting it to a PC.
Jul 05, 2008 | Sony Handycam CCD-TRV12 Camcorder
I was given a nice sony handycam camcorder. i was told the battery is probley dead
Batteries have a limited life even if they are constantly charged.
Leaving batteries in constant charge will limit their life by causing gas leakage. Once depleted, they must be replaced. There is also a small button battery that keeps unit memory up, if you do not use camera for months at a time, replace this battery also.
Ni-Cad batteries need to be refreshed ony once a month by discharging them fully, then recharging them fully for best performance to erase memory effect
May 01, 2008 | Sony Handycam CCD-TRV37 Camcorder
No power Sony Handycam Model CCD-FX620
there are fuses ,but they are small solder in types, all fx series camcorder have a common problem with the rear power board working it's way loose and unplugging itself from the main board. these units have alot of solder connection issue due to sony's use of poor solder back in the earily 90's
Sep 14, 2007 | Sony Handycam DCR-TRV250E Digital...
Panasonic PV-GS2 Mini DV Digital Camcorder Logo
127 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
