Question about Mitsubishi HS-U680 VHS VCR
Mitsubishi HS-U680 VCR
Every thing seems to work on the VCR except there is no picture or sound.
  • 579 Answers
Here are the possibilities:
1. really dirty heads - both video and audio
2. TV is not selecting the right input for the VCR.
3. difficult (but rare) failure in the VCR output circuitry.
Hope Ya Fix it!
Posted on Jan 24, 2008
How to fix TV
If you are willing to take a chance...and you have some technical skills you may be able to repair it. I was able to replace 2 capacitors on my power board for under $5. I had no picture, no sound. Not saying that is what is your problem. Search the internet for your model number and no picture. I see several youtubes on yours as well.
Jan 24, 2015 | Samsung LN46C630K1FXZA - 46in Lcd Hdtv...
We have a new vcr snowy
It seems that you need to take the new unit back for exchange, since you are using the same output for the vcr and the dvd and your dvd is giving you a good picture, the vcr is acting up and since it's new either exchange or repair will be needed.
Sep 01, 2009 | Philips Magnavox TS3260C 32" TV
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
No Picture
check out the tip in my profile or use a wet cleaning tape
Mar 31, 2008 | GE 13TVR62 Combo
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Can't Receive Ch 23-48
It looks to me that u still have some dry joints, look carefully with a magnifier glass and resolder those bad joints
Dec 26, 2006 | Toshiba 36A60 36" TV
VCR not working with TV
What you state cannot be logical. If picture is freezing, then the VCR is at fault. But you state that the VCR works fine when played, and viewed on another TV. So, the only explanation I can think of is that there is some thing faulty with your VCR. Probably, when you play a tape, the picture freezes. This could be 'cos the Capstan motor of the VCR freezes. Common problem with aged VCRs. Just requires a spot of grease, and service. IT CANNOT BE THE TV AT FAULT!!!!
Aug 22, 2006 | Toshiba CZ32T31 TV
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
