I need simple instructions to connect my mac and my xbox 360 so i can watch my mac vids via the xbox on tv.... and have the xbox share my internet connection! i currently have a wireless router which my mac talks to for broadband via airport
Kind of a big slap in the face for Microsoft, don't you think? Some pals of mine said Xbox blocks Mac media connections because they don't want Apple and Microsoft products mixing, although you can listen to an iPod on your Xbox. So, I'm not sure you can.
I've never heard of a Wireless Adapter turning amber or orange? This can be a simple light problem inside your Xbox 360. If it were fixed, the highest possibility is that color should be red. If so, this means the connection is not strong enough to your modem, and adapter. You will have move your Xbox 360 console closer to your wireless modem for the connection to be the best.
Remember to thumbs up this solution if it helps, if not comment for further assistance.
Plug your xbox into the laptop with an ethernet cable
Turn on your xbox
On your laptop press start, click on network
In the blue bar across the top click network and sharing center
click on manage network connections
right click on local area connection
click properties
click sharing tab
untick top box.
Go on your my xbox page, scroll over to the right to the system settings page, network settings,test connection.
This works for me.
wel your o2 router is basically ur internet so if that does not work i reccomend you switch to broadband and buy the wireless adaptor for the xbox 360 and use that if you dont no how to set that up send me an e-mail to [email protected] and i will walk you through it step by step till ur up and running AND PLZ RATE THIS FOR I WILL NEED YOUR VOTE TO CONTINUE HELPING OTHERS WIT THE SAME PROBLEM YOU ARE HAVING TANKS.
ok well I found a fix but it may not be simple. anyway, i got my xbox360 to work off of my girlfriends laptop by feeding internet to the laptop from the cable modem via usb and then from the laptop to the xbox360 via ethernet. just right click usb connection in network connections and click sharing tab, then activate sharing and tell it to share connection with lan connection... you can also share through wireless if your xbox is wireless. I tried running all this through a dsl wireless router and a basic hub and both of them gave ip address and mtu errors... good luck
Windows media center is a little complicatd to use. The biggest problem with it is you have to have your movies rated. If you want a fast and simple way to connect the two is use a program called tversity. http://www.tversity.com/
It is free and extremely easy to use. Once you install it, you will need to show it which folders to share. Then go to your xbox dashboard and go to My xbox, the scroll right to video library. Once there you should see tversity on (your computer name)
Choose this option and you will then be able to play all your media on your xbox including all your songs and movies.
