Question about Magellan GPS 310 GPS Receiver
MAGELLAN 310 NOT TRACKING
HELLO , MY MAGELLAN GPS 310 WILL NOT LOCK / TRACK SATS. IT WILL ALSO DISPLAY A "FAIL MESSAGE " IF YOU TURN IT ON WHILE HOLDING DOWN ON THE GO TO BUTTON ( AFTER GOING THROUGH A KEYPAD CHECK AND A DISPLAY CHECK ) . DOES MY UNIT NEED TO BE RESET ( AND IF SO , HOW DO I ACCOMPLISH THIS ) , OR IS MY UNIT JUST TRASH AT THIS POINT ? THANKS .
E-MAIL = kevin.mize@us.army.mil
  • 4 more comments
  • zamboanga Mar 18, 2008
    Hi
    I have the same problem The 310 powers up & appears to be working but never finds its position
    The 310 has not been used for some time 2 years + On trying now I get
    the same result as you do I have emailed Magellan but am not
    hopeful of any useful reply
    Regards
    Nick
  • trailermaker May 24, 2008
    My Magellan 310 is alson not picking up satalites and the time is speeding along (half an hour in a few seconds!) I have tried pressing right arrow and power at the same time but still not working. Any one with any ideas?
  • bugs2008 Jul 07, 2008
    I have the same problem. After not having used ithe unit for about a year the time is now leaping ahead and the unit doesn't function properly at all. I have tried the: "press start, hold right arrow" procedure without success. I have tried switching on and holding all the different buttons individually but nothing seems to work. Has anyone resloved this problem and if so how please?
  • Mr Em Jul 13, 2008
    My Magellan 310 will only accept a max. of two satellites though up to seven small indicator rings will show. Hence I am unable to get an initial position fix.Have tried all the suggestions so far given ( i.e. right arrow and power buttons, bottom rt corner of screen and power button but all I get is the initial start-up screen. Any more ideas?
  • brian24_tx Mar 21, 2009
    I have a Magellan Gps 310 that is several years old. I
    turned it on for the first time in over a year and will not display
    correct location. The clock is also moving too fast. I have tried ez
    start and reseting the device several times with the right arrow
    power-up method. Nothing seems to fix the issue. I have had lock on to
    as many as 7 satelites after the reset yet it still will not display
    correct lat and long. Any help or suggestions would be wonderful.
  • Anonymous Mar 27, 2014
    310 appears to have a timer function which automatically changes displays from the one showing the current track to the startup display or the compass
  • 3 Answers
Turn on the power while holding the right arrow. This resets the unit. You will then have to reset the time, date, and location.
Posted on May 07, 2008
Thanks. Initially, my 310 showed wrong position, time and date, but correcting them resulted more mess. No satellites were found and tracking after being locked into (even 8 or more) satellites did not start at all.
Powering off by holding first pwr then right arrow button down: Yes it does work, but you actually need several (appr. 4-5)attempts and furthermore, you need to hold on pwr and right arrow down while turning it on. No extra waiting over night or anything else was needed - just the right timing when holding the buttons. After that you will be asked erase memory, YES/NO, and answering yes it will be resetting like EZSetup.
Posted on Jul 26, 2008
The 'right arrow / power' combination does work but it may take several attempts. Leave the GPS 'off' for an hour or so before first trying it.
I then had to leave my 310 on overnight before it eventually managed to track 3 or more satellites. So far today it has worked perfectly and has been tracking up to 6 satellites! (But I'm keeping my fingers crossed that it continues.)
Posted on Jul 14, 2008
I have persisted with turning power on while holding right arrow and finallly it did come up "erase memory?" after pressing yes and resetting it DOES WORK. Great thanks a lot
Posted on May 25, 2008
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Everything works but the GPS. Nothing shows up
May sound stupid but make sure you are outside and give it 5 mins to track the sats. If no joy press the reset button.
Dec 06, 2009 | Magellan Maestro 3250 GPS
Where can I find instruction manual for the GPS 310
Your manual can be found here.
http://auto.manualsonline.com/manuals/mfg/magellan_thales_navigation/gps_receiver.html
Jul 25, 2009 | Magellan GPS 310 GPS Receiver
Magellan wont get signal?
charge the battery fully, then set it outside in clear view of the open sky. it may take as much as 30 minutes to acquire the sats if that fails, try and leave it out longer...does it appear to try and link to ANY sats. on the map screen in the top righ t corner is a icon with bars in it, tap that and you should see it trying to acquire sats. if not, you might have other problems
Jun 02, 2009 | Magellan Maestro 4040 GPS Receiver
Not tracking
Reset the unit by clearing the memory. Hold the RIGHT ARROW key and press the POWER BUTTON, while holdingthe RIGHT ARROW key until the DELETE MEMORY screen appears. Select YES and press ENTER. Then procede to initialize the GPS. Leave it outdoors for an hour or so to acquire satelite feed.
Apr 20, 2009 | Magellan GPS 310 GPS Receiver
Magellan GPS 310 screen or software gone haywire...
the motherboard is probley sendint the screen on the gps the wrong info
your best bet would be to take it into a gps place and get them to have a look at it
Jul 19, 2008 | Magellan GPS 310 GPS Receiver
Magellan 310
I Experienced the same problem the last two weeks. I read your suggestion about the right key/power button. The GPS asked me wheter I wanted to clear the memory yes or no. After "yes" i had to reenter my country and date/time. After doing this it took gps310 more than an hour to get its first fix. But it works again.
May 21, 2008 | Magellan GPS 310 GPS Receiver
Magellan 310 Signal Won't Lock In
Turn on the power while holding down the right arrow. This will reset the unit. You will have to reset the location, date, and time.
Nov 26, 2007 | Magellan GPS 310 GPS Receiver
I can't find my owner's manual
You can download a pdf of the owner's manual here: http://www.magellangps.com/assets/manuals/gps_310_315_en.pdf
Aug 12, 2007 | Magellan GPS 310 GPS Receiver
Magellan GPS 310 GPS Receiver Logo
889 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
