Did you check the board could be that issue check with a tech guy and verify that
Most likely the panel is being overdriven by the Y sustain circuits. To adjust this properly you need an oscilloscope but you can decrease the Vs voltage (probably about 180V) by up to 10 volts with a potentiometer on the switching power supply board. This is not an approved by the book way to get rid of sparkles but it works and I do not believe that it degrades performance or can cause any harmful effects. You don't have to measure the voltage. Decrease Vs until the spots go away.
we adjusted the voltage on the back and the sparkles are gone. Thanks for the help.
