Speakers not working
My computer recently broke and i had to get xp installed again and my speakers used to work fine until this.no sound will come out at all now. i used to be on xp but now im on xp proffessional not sure if that helps?
  • 43 Answers
What you need to do is install new sound drivers, now depending on how your system is set up there are a couple possible solutions. Now I will walk you through a couple steps but before I begin I want you to remember something for me and I will explaine in further detail later. BEFORE INSTALLING NEW AUDIO DRIVERS YOU MUST FIRST UN-INSTALL ANY DRIVERS THAT ARE CURRENTLY INSTALLED. That is very important as if this step is skipped the problem will still exist.
1st solution go into your control panal, find the icon for your sound options, double click on that icon. Go into the properties and uninstall all audio drivers. Then make sure your P.C. is connected to the internet and restart your computer. When the P.C. restarts it will look for driver for your audio device, it will also look online to try to find drivers. This should fix your problem, just follow the instructions and install your new driver. However for the sake of giving you a wider set of tools I will list a couple other options.
2nd solution check Windows update, let them scan your system and see if they have an updated audio driver. If they do then un-install any current audio drivers and run the update.
3rd solution if you have an onboard sound card (it is sodderd to the motherboard and canot be removed) You may have to go to the website of the manafactuer of your motherboard and enter the model number of your motherboard, they should have instructions for updating the audio drivers for your sound card. You may have to find the support section of their website .
4th solution If you have a PCI video card (it slides into a PCI slot on your motherboard and can be removed from the computer) You will have to find the manufacture of the sound card, sometimes the easiest way to get this info is to open the side of your computer (remember to power off and unplug your computer before removing the side) and looking at the card its self as most manfacutuers will have their name on the card, take note you may also need a model number off of the card for some of the manufactuers. Find the website for your videocard and try to find drivers for your particular card, keep in mind again these companies make many diffrent models so there may be diffrent drivers for diffrent video cards and even drivers based on the operating system you are using. Once you find the driver you need make sure you have un-installed any drivers that were on your computer and download and install your new drivers.
Hope this helps
Posted on Jan 24, 2008
Recently had to re-install Windows XP onto our computer; I just need a driver for my speakers because I have no sound right now. The speakers work perfectly fine, they are Altec Lansing VS2220. I don't...
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 07, 2010 | Altec Lansing VS2220 Computer Speakers
Thinkpad T41 with XP-sp3: No sound / working fine until yesterday
Hi. Try plugging in an external speaker just to test the issue. It could be just the speaker of the laptop is having the problem. If you were able to hear the sound from the external speaker then the problem is the built in speaker of the computer. If there is no sound coming out to external speakers. Try to reinstall the driver of your soundcard.
Jun 17, 2010 | IBM ThinkPad T41 Notebook
Speakers work, no sound
you should install *********** board drivers again
Mar 04, 2010 | Logitech X-230 Computer Speakers
I have an Dell Dimension E510 running windows XP. I have 5.1 surround sound speakers that were working fine until recently. Only 2 speakers work; left and right. None of the others have sound. I have...
Reinstall the software for the sound system, this should redetect the speakers properly as 5.1 surround sound speakers.
If you do this and it still doesn't work then the speakers are bad and your sound system would need to be replaced.
Dec 01, 2009 | Dell Dimension E510 PC Desktop
Computer can't find the damn speakers
I didn't find the x-530 but I did find the install guide for the x-540 which I assume is similar to yours. Most speakers (including yours) do NOT require software to work. If anything it's the sound card on your PC that requires drivers to work but if that is working fine then your speakers should plug and play and work w/o any software.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=5FDKVTAj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=5524&p_created=1160578991&p_olh=0
Copy and paste the entire contents above into your address bar to go to installation guide. If you have it connected correctly and it is receiving power then perhaps your Sound Card is not working correctly.
Jun 21, 2009 | Logitech X-530 Computer Speakers
Chipmunk speed
I would try to update the drivers for your sound card. If there is not an update try uninstalling the driver and re-installing it again. I had this problem with my speakers recently and this worked for me. Did not have the chipmunks sound though.
Feb 23, 2009 | Audio Players & Recorders
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Just re installed windows xp on new hard drive, built-in speakers no longer functioning
Visit support.dell.com, click on drivers and downloads, and then click on the service tag option.... enter the service tag from the bottom side of the laptop... it will then display the list of drivers for that laptop.
Download and install the audio drivers and any other ones that you need.... let me know if that solves it for you. Make sure they are for your laptop model and operating system.
Oct 23, 2007 | Dell Latitude D600 Notebook
Speakers are not being recognised
i would like to know if your on board soud or sound card is not being recognized by your system? as far as i know speaker will not work if your sound device driver is not installed. so maybe theres nothing wrong with your speakers. try to go to my computer properties go to system device hardware and see if there is an yellow exclamation in your sound device. if there is, update the driver using the provided cd from your motherboard, if its on board sound device. but if its a sound card, update the driver using the cd provided from your sound card. but if your sound device is ok and there no yellow exclamation, probably you hooked your speaker connector to the wrong jack. it should be the color green one. try and good luck
Jan 20, 2007 | Generic Memory 2-Piece Amplified...
Computer speakers
It sounds like you have viral infections. http://housecall.trendmicro.com runs from your web browser (I would suggest using Internet Explorer). http://www.download.com/3405-8022-5153545.html?part=dl-ad-aware&subj=dl&tag=top5 This is Adaware, it will remove the spyware on your computer. This one needs to be downloaded. Finally, If you want to protect yourself from future viruses/spyware, use Mozilla Firefox (http://www.mozilla.com/firefox/) instead of Internet Explorer-the change is huge.
Jul 03, 2006 | Cyber Acoustics CA-3300 Computer Speakers
206 people viewed this question
 Grubhead
Grubhead
