Question about Candy CNW156 Front Load Washer / Dryer
Drying cycle When the machine is put on the drying cycle it no longer drys the clothes. When I open the door there is a lot of steam but the clothes are still wet, although they are hot. They do dry after a second or third cycle but it used to only take one.
  • 126 Answers
Is the drying fan rotating(you should hear this)? Or the watertap closed. It uses cold water to make the steam into condense. If tap is closed, the machine has no water to cool the steam with. Check lint filter.
Posted on Jan 24, 2008
Zanussi Washer Dryer wont wash!
Sounds like the switch that tells the controller that the door is closed and locked is actually bad or the plastic molded part holding the switch is broken. Inspect the interface for cracks.
Nov 22, 2014 | Zanussi Washing Machines
My LG washer/dyer fills up with water after its done running, it washes and drys then fills up
something is holding the input valve open small pieces of rust etc. will do this .that is why they put screens in the ends of the hoses
Sep 23, 2017 | Washing Machines
My Bosch Classixx washer dryer has stopped drying and the clothes come out steaming hot and steam escapes from the powder drawer during the drying cycle. I have had an engineer out and he says the airflow...
if you have a very large load of clothes in the machine on the dry cycle, what tends to happen is that the clothes are not flapping around in the drum loosely but they are going around the drum in a big mass, with the result that they just get very very hot and steam will escape out the soapbox draw. When this happens, heater unit that becomes overheated ant the thermostats will eventualy cut out resulting in cold air being circulated instead of hot. You will need to have them replaced again. when replaced, put on a drycycle with only a few garments in the machine and you will see a big difference in it perfomance. washer/dryers are not very effective on the drying cycles with a full washload.
if you need any more help, you may email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WVF 2402 Front Load...
Bosch Exxcel WVT1260 On drying the heater seems
Check your venting. If the water vapor can't get all the way outside, your dry times will be longer than usual and the steam will come out the front when you open the door. You may need to clean your ducting, which is a good idea anyway to reduce fire risk.
Nov 13, 2009 | Washing Machines
Is it normal to see steam coming out of the dishwasher in the drying cycle?
Yes, The colder the room its in the more steam you will see. It will look like more steam if sun light is shinning over it. Just like your clothes dryer blowing steam out side. Its just drying.
Oct 30, 2009 | Dishwashers
Kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Drying cycle problems
Take the door fascia off, and you'll see a pipe from the steam outlet to the Soap Dispenser in the door.
Take that off, and flush out the small bit of food that is blocking the tube.
Put the cleared pipe back in situ.
Run machine, you should get steam, and no water.
When it blocks again, and you get the water again, repeat unblocking process etc...
Jul 16, 2008 | Miele 24 in. G665 Built-in Dishwasher
LG WM 3431 does not dry
Dryer / drying troubles - DIY repairs WD-12320RD / WM3431H. It was difficult to find suitable solutions so I shall share my experiences here. I live in Malaysia and purchased the LG washer-dryer model WD-12320RD TROMM (240V) in January 2006. WD-12320RD should be similar to WM3431H, just compare and verity features available at LG's Singapore website http://sg.lge.com. However, WD-12320RD model is no longer available locally. Both model's features are essentially the same since I relied on the WM3431H service manual downloaded from http://136.166.4.200/SubPages/DA_Laundry.htm for my repairs.
Fixing the machine would require relevant skills and plenty of common sense. Do this at your own risk and I am not responsible for your screw-ups.
Trouble date: January 2006
Symptoms: Damp clothes. Steam present when the door was opened and the door was also wet.
Solutions attempted: New washer-dryer drying under “Very” (More) didn’t worked. Machine was still under warranty and LG repairman was quick to respond and helpful. Diagnosed the problem to be a faulty PWB Assembly (main). Replaced PWB Assembly with a new version i.e. without “Cd” (cool down) feature. Machine worked as it should and clothes were dry even under “Cupboard” (Normal) mode.
Trouble date: March 2008
Symptoms: Similar to January 2006. Problem persisted, even after running drying cycle twice.
Solutions attempted: Dryer under “Very” (More) didn’t worked. First diagnosis, faulty Heater Assembly and Motor Assembly (Fan) located in dryer Duct (Inlet). Replaced the Thermostat Assembly, the Fan and also thoroughly cleaned the Duct Assembly (condensing). It was full of lint but no hairs, etc. Problem persisted.
Tried “Time” drying setting at 2h 30m and the drying worked a little better but the clothes were still slightly damp.
Tried Cupboard again and this time I observed the display was reduced to 10m or 6m after only ½h passed. Ran the cycle again but also used a separate kitchen timer as a reference control by setting both timers at 2h 30m. Confirmed the drying cycle ended abruptly in about 45m while the kitchen timer was still running.
Tried “Low Temp” mode and the drying cycle lasted between 3½h and 4h. During the drying cycle, time display would stay frozen at 6m when the actual time passed was more than 1h. Once completed, the clothes were dry but some steam was still present. The door was dry too.
Replaced the PWB Assembly and dryer worked again. Clothes were dry as toast.
Lessons learnt:
Symptoms: Immediately after drying cycle, damp clothes, door is wet and steam present.
Recommended action: Try all drying modes, observe behaviour compare with the above. Use a separate timer as reference to confirm drying cycle ended abruptly. During cycle also observe whirring sound to be sure that the dryer fan motor was running and the top right hand side of the machine felt warm because of the heater. Thoroughly clean the Duct Assembly (condensing).
Tips on cleaning Duct Assembly: Unplug power cord and ensure machine is cool.
Step 1 - (note: for this step, very little guidance was found in manual) remove back panel to access the rubber bellows connecting the Duct Assembly to the tub. It should be located at the lower left side. Before removing the bellows, line the base with some towels in case Duct was flooded. Wash bellows thoroughly. Remove any other lint or visible obstructions from the Duct and tub openings. Re-attach and secure bellows.
Step 2 - remove the Heater Assembly and Fan covers to expose the heating element. Scrub the entire inside walls with moist toothbrush. Extend the handle if required. Don't use sharp objects to clean the Duct. It would be easier to remove lint if the inside walls were moisten with water using a manual spray pump. Exercise extreme care and do not wet other parts of the machine. Remove the loose lint and rinse entire area carefully using cups of water and all the remaining lint would flow down the Duct into the tub and later, exit through the drain hose. If the Duct is blocked, the water may fill up the Duct. Not to worry, try removing the obstruction (likely to be lint or hair) with a suitable tool, probably a stiff rod with a blunt, L-shaped end. Finally, clean by rinsing with water and dry the covers and Fan before re-assembling all the parts. Repeat Step 1 if necessary.
Recommended solution: If symptoms persist, most likely the PWB Assembly has conked out, even if it was a new machine as in my case and it appears to be so for many users as well.
User tips for best performance: Maximum load by volume, clothes should not exceed 70% of tub. When drying efficiency is affected, cleaning maintenance is required.
extracted from http://www99.epinions.com/content_427670867588?alert_type=0&submit=Submit
please visit and leave a positive comment if your trouble was solved. tq.
Jan 29, 2008 | LG WM3431 Front Load Washer / Dryer
Dryer heats but no condensing of steam
The cold water feeds for condenser cooling and for wash cycle drum fill are controlled by separate solenoid valves (manifolded together at the cold water inlet hose union). When the solenoid on my condenser coolant valve failed a couple of years back, I got symptoms like yours. A new pair of valves isn't expensive to buy and is a trivial job to fit. If this is what has been happening, suggest you also inspect the insides of your dryer fan and of the pump - neither of mine took really kindly to having been cooked for hours on end. Alastair.
Oct 16, 2006 | Candy DQW150 Front Load Washer / Dryer
Candy CNW156 Front Load Washer / Dryer Logo
349 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
