The machine is a white westinghouse
model mwx223rew1.
This machine fills up, drains, and clicks through all the cycles,
but nothing spins.
I do hear the motor working on rinse cycle.
It sounds like something is spinning, butnothing is moving
Hi early1234, where are the five bolts located. I appreciate the diagram but that does not tell me how to get in the machine. can you tell me? TimHi early1234, where are the five bolts located. I appreciate the diagram but that does not tell me how to get in the machine. can you tell me?
Tim
You can't post conmments that contain an email address.
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sorry, I can't help you. This is the area for asking questions about computer monitors, not washing machines. You clicked the wrong link. Look at the top of the page, click the Westinghouse link and then on washing machine. Enter your question there.
Does the washer fill normally and just stop? Or, does the washer fill, go through a complete cycle, and just won't drain? There could be a couple of problems that cause a no drain issue.
1. FILL NORMALLY & STOPS, WILL NOT SPIN - This is usually a bad lid switch. If you open and close the lid, you should hear a "click", indicating the switch is working.
2. FILL NORMALLY, AGITATES, WILL NOT DRAIN - This could be a clogged drain pump, pinched hose, clogged rain line.
Also, you need to make sure timer is advancing properly. If the timer never advances, the washer will fill, but won't go into agitate or spin. Let me know if this is helpful.
Tim
