Hello, when the clothes are partly wet when cycle is complete then check these. 1. Motor coupler 2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it. SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace. Thanks
your water fill valves are leaking severely,you should see water dripping in there all the time if its this bad and your clothes should still be wet,not damp even after a good spin after the final spin
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
These washers use very little water. (about 2 inches in the bottom of the wash tub) The actual amount used will vary based on the volume of clothes and the type. (snythetic clothes do not absorb much water, but put in a load of cotton towels, for example, and the clothes absorb the water, causing the water level to drop, and the machine will add more water to return the level to the set point, which usually takes a several short fills, over a couple minutes)
To see that the clothes are indeed wet, just pause the machine a few minutes into the cycle. The door will unlock, and you can feel how wet they are. When the cycle completes, these machines spin so much faster (about twice as fast as most top loading machines) that the clothes feel very dry. (thus reduced drying time, and additional energy savings) Because of the lower water usage (about 12 gallons vs. about 45 for a top loader) make sure you only use 1 to 2 (max) tablespoons of HE detergent per cycle, and only 1 teaspoon of fabric softner if you use it. (don't use fabric softner on towels) Using too much addatives will cause odor issues, and possible performance issues.
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like. Please let me know if I can assist you further. Thanks Vic
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
