Question about Irons
How can fix sedu hair irons?
I'm gutted. My expensive hardly used sedu 1.5" hair irons have blown. i say blown because i took them to Europe were the voltage is 220V. I had a currency converter, they worked, overheated and OUT! I took a good look at home and i see the plug has a big crack in it. Could this be a reason they dont work?
HELP! I want them fixed (for a reasonable price). Who can do it?
  • Anonymous May 04, 2009
    I have the exact same problem! I purchased the device in May 2006, but only started using it in the winter of 2007. That means my warranty has expired and I can't have the device replaced. If anyone knows of places where I can get this fixed I so appreciate it!
  • Kathy Ryan
    Kathy Ryan Apr 02, 2014
    I have one, too. My cord has started acting fussy--turning the iron off and on when it is twisted certain ways. It ticks me off. I paid a lot of money for this iron and I always take care when I put it away. I\'ll never buy another one!!
6ya staff
SOURCE:
Jaime Hernandez
  • 2337 Answers
SOURCE: Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Posted on Apr 21, 2008
Anonymous
  • 255 Answers
SOURCE: Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
Posted on May 29, 2009
behram66
  • 90 Answers
SOURCE: The electrical at home trips everytime I swicth ON the AZUR4330??
Hi
I know its hard to say... But please get a new iron....
You me y do more harm to other electricals just trying to fix the iron....
I know this is not a great solution byt a pratical one...
Warm Regards
Berry
Posted on Feb 02, 2010
Anonymous
  • 3 Answers
SOURCE: I am a seamstress and need a very good iron for my
I'm having the same problem...no power, no lights...nothing. Just went off. All I can suggest is that you contact Euro-Pro's customer service at 1-800-798-7398. Good Luck
Posted on Apr 28, 2010
DiYerTech
Roland Wong
  • 70 Answers
SOURCE: What happens if I use CLR in my steam iron?
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: [email protected]
Posted on Jun 06, 2010
Sedu Icon flat iron keeps beeping, only heats on one side
Heating element or control circuitry defective
May 30, 2018 | Irons
How do I get the tv schedule for curling this fall and winter ????
Please next time use Google for this question. We can't find it here in Europe.
Oct 05, 2014 | Remington Instant Curls 1 1/4 Curling Iron
SEDU flat iron won't turn on when i plug it in...
flat iron has large metal foil so change the procdure
Jan 24, 2014 | Sedu Pro Ionic Ceramic Tourmaline Flat...
I have a GHD Hair iron, it just went off while using it, now it wont come back on.
There are many things to cause them to stop. You will need to open them up and start testing with a multi meter.
Oct 05, 2013 | GHD Good Hair Day Original Ceramic Flat...
How to stop a flat iron from turning on and off when being used
sounds like a bad connection in the power lead be careful about a possible short hazard ZAP!!! Find a handyman to fix it.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Sedu flat iron
because it is automatic so it turns on and off after heating at a certain temperature it turns off automatically.
My Azure iron has just stopped working after two years. As dead as a DoDo. Checked fuse and wiring inside is intact.It still looks brand new, do I really have to bin it?! Bob Harvey.
yea you probably should! irons are no point fixing and by the sounds of things its blown up! i bought an expensive one and it didnt even last a year! we had warranty so we got a new one free
Jun 30, 2009 | Philips Irons
Repair of Steam Iron
Hi, honestly if there is a short circuit to ground and you are trying to troubleshoot this, I would not advise you doing this (I do electronic tech/engineering everyday) and am uncomfortable doing it, as it is a shock hazard to continue using the device, especially if significant others are using the appliance. Unless I am SURE I can fix the problem AND I know how to test for circuit isolation as recommended by UL, CE and other safety governing bodies...i.e. "Know about HI POT and Leakage Testing techniques."
That said, since you have already dismantled and accessed the "guts", there is probably a fastener or moulded retainer you missed. Probably a good idea to try and locate a schematic or reverse engineer it, making sure you draw lots of assembly and disassembly diagrams as you go if you are so inclined
Jul 12, 2008 | Rowenta Power Duo Iron
Irons Logo
419 people viewed this question
Top Irons Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
