Question about Toshiba Satellite A15-S157 Notebook
Reformatted hard drive won't boot
I reformatted the hard drive with the Toshiba recovery disk. When I power up now all I get is the following:
GRUB Loading stage1.5.
GRUB loadin, please wait...
Error 17y (the y has 2 dots over it)
Any ideas, Thank you in advance
  • brian c
    brian c May 11, 2010
    GRUB is a bootloader for Linux operating systems. I'm not sure why it would be giving you that message is you used a windows disk...
    Are you trying to install Linux?
The grub loader is for linux, what it is telling you is that the file the boot loader is looking for was not found (that would be the case because you just reformated it). grub will also complain and fail to boot if the boot file is located past track 1024 (wich would be the case if you installed a significantly larger hard disk). I think what you need to do is delete all the partitions using windows (or dos)
re partition the drive (that will usualy reload the standard boot loader) and see what happens. if you need to install linux then install it on the first partition.
Posted on Jan 23, 2008
Toshiba laptop L450/L450D satellite won,t reboot from hard disk drive
Try F12, F2 or F1 on power up to get into the boot menu.
Once in there change the boot sequence to try booting from the CD/DVD drive first and hard drive second. There are various options to download a rescue disk based on Linux on the internet. They download as .iso files which you save onto a CD/DVD.
You need to do this on another computer connected to the internet.
My favourite is KNOPPIX as it is a windows type GUI desktop. you can then try to repair you hard drive. Knoppix will exist in RAM only as long as the computer is turned on, so it wont damage your computer.
KNOPPIX Live Linux Filesystem On CD
Sep 13, 2014 | Toshiba Satellite Computers & Internet
Why my Toshiba Satekkite laptop won't reformat the hard drive?
Why are you trying to reformat the drive ? The entire operating system and all files will be destroyed if you do this. To reformat the drive requires an external program on a disk that would allow you to reinstall windows from scratch. Most Bios chips can do a reformat but accessing these low level programs is for pros only and varies widely from machine to machine. Unless you have a nasty Trojan, virus or worm that can't be removed any other way I would not do this. You will need a working copy of a boot disk to get the machine up and running after the reformat. Then you can reinstall the Operating System. If you had been successful in your reformat you would have found yourself with a DEAD MACHINE unless you had a boot disk ready.
May 25, 2014 | Toshiba Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Reformat my computer to windows 7
ATTENTION!
Reformatting a computer will reset it to the factor image, all data must be backed up or it WILL be lost. There are several reasons to reformat a hard drive. A few reasons include but are not limited to: driver issues, virus, cleaning up, getting rid of the computer, etc.
RECOVERY DISKS!
Every new windows 7 owner should know that the new computers are not supplied with recovery disks anymore. The manufacturer allows the user to create one set of disks upon the purchase of a new machine. It is important to create the disks early as driver issues and viruses may arise. In order to create recovery disks on windows 7 you want to click on the start menu. Next, type in recovery in the Start Search option area. Next, click on recovery disk creation and follow the process. It will require that you have about 3 dvds or about 7 cds to create the recovery disk.
REFORMATING HARD DRIVE!
Once the recovery disks have been made reformatting windows 7 is quite simple. Insert the recovery disks into the cd/dvd tray on the machine. You are now going to want to turn the computer off. When the computer has turned off, go ahead and turn it back on. A screen should pop up asking you whether you want to boot from Hard Drive or Disk. Choose the disk option. After you make it this far it is a downhill process. Next you follow the on-screen instruction make sure you reformat the machine, not recover it.
Apr 14, 2011 | Computers & Internet
How do i reboot or recover my nb505 toshiba netbook
Reinstall Windows from a Disk
1 Turn on your Toshiba . Insert your recovery disk or the original Windows operating system DVD
into the 's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba . In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba . In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba NB505N508BL 10.1" Intel Atom...
I installed linux ubuntu remix on my ASUS Eee 1001PXB-BK301 multiboot, then i deleted ubuntu after not using it anymore using windows xp disk mangement and found myself without a mbr with grub saying grub...
What you need is SATA controller drivers to be downloaded while starting windows xp disk or ERD Commander.
Since Asus Eee does not have an internal Floppy Disk Drive (FDD), you need to use an external USB FDD.:
Step one: You would like to connect an external USB FDD.
Step two: copy scsi/sata Hardware Access Layer (HAL) Drivers for you laptop to a floppy disk
Step three: during the XP boot process press F6 and follow the prompts to insert a floppy disk with HAL scsi/sata drivers.
Step four: Finish the boot process and run fix MBR.
There is another easy way:
If you can get a Knoppix USB flash drive, you can boot it up from Knoppix and run the following command in the terminal window: sudo ms-sys -m /dev/sda.
Hope This Helps
Jan 29, 2011 | ASUS Eee PC Netbook
Want to bring it back to factory new
The best way to reset your Laptop to Factory Default is to reformat it. Depending on which version of Windows you have this will create a directory in your Hard Drive called Windows.old, or depending on whether or not you deleted the partition, it will erase everything. You'll want to back up your hard drive if you have anything worth saving.
Beyond that, pop in your recovery disk, or if you don't have it, put in your Windows disk, then restart your computer. When your computer is booting up, head into the BIOS and set your computer to boot from your DVD Drive. If you aren't sure how to do this then reformatting is probably not a good idea. Once you've booted from the disk, just follow the instructions to reformat.
Dec 26, 2010 | Toshiba Satelite 2405-S201 Notebook
Error Loading operating system
CHECK your bios setting first, and make sure, in hard disk boot priority section, your external hard disk is recognised and set as the first boot device. YOU NEED TO BE SURE YOUR BIOS SUPPORT BOOTING FROM USB FIRST.
IF the hard disk is there u can do several stuff to boot it:(unplug any internal hard disk first, TO MAKE BYPASS CONFLECT ISSUES)
- make sure the drive is seen, whene you are trying to install windows.
- go to recovery console in the setup disk, and reset you master boot record, type:1- fixmbr (or fixmbr c:) >>> WHERE "C:" IS YOU WINDOWS INSTALLATION DESTINATION!
2- fixboot
and then restart and try again......
- try to download plopboot manager, burn it to disk, and boot it, try to load your hard disk frome there.
- install any boot loader, like lilo or grub if you are familiar with, they can boot any os you like!
You can always install Grub to your Master Boot Record of the initial internel hard disk, **** you need to have basic knowlege on how to edit the menu.lst inside grub folder, and basic knowlege of linux partitioning schemr, becoz GRUB need to be installed there as well, **** whene you are already familiar with its use, you can boot any thing you like, even with a friendly boot menu at startup alowing you to choose the option you want to boot.
N.B: make sure you have googled and read about grub, and how to install in, if u have a windows installation on the internal hard disk and afraid to loos it, there is a tool called super grub disk, google for it and download it, it can be installed from windows, and it can automaticaly load windows ntldr/boot.ini.
dg luck.
Dec 31, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Want to know the steps to reformat Toshiba - Satellite Pro
Your data - In order to ensure don't copy any infected data backup as few executables as possible. BEFORE restoring your data make sure you have antivirus installed and up to date. Perform a full scan after copying the data back to your lt. Put in the recovery disk and restart your computer. Look for a prompt on the screen to "boot from disk" while it is booting. Press the key it says to press and follow the directions from there. If there isn't a prompt to boot from disk try pressing Alt and F10 while it boots.
Jun 03, 2009 | Toshiba Satellite Pro 490XCDT Notebook
How to reformat R52 ibm thinkpad
Your laptop should have come with a recovery disk, you will need to boot to that disk following the onscreen steps for formatting and restoring the operating system files. Furthermore, if your system did not come with a recovery disk, or you have a Windows XP/Vista disk you can boot to that instead.
Windows XP Install:
After the installation system boots, the setup prompt will prompt you for searching the system for previously installed versions of Windows; bypass the recovery option after the search is complete. The setup will then display a list of Hard Drives to install Windows; follow the key for deleting the partition (press "D" to delete). Once the partition has been deleted highlight the "free hard drive space" and press "Enter" then you will be prompted to format the drive and install Windows. Moreover, you should right down the Windows Product Key off the sticker on the bottom of your laptop; you'll be asked for that key after the setup restarts your computer assuming you are using that license for that version of Windows.
Windows Vista Install:
When you boot to the Vista DVD you will be prompted to enter the product key as soon as the setup loads. Select the Hard Drive with the mouse, then left-click the format button on the right pane. Continue with the installation.
Nov 29, 2008 | IBM ThinkPad R52 Notebook
Toshiba Satellite A15-S157 Notebook Logo
211 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
