Question about Dell Axim X5 Pocket PC
Installing San Disk Wireless Lan Card for Dell AXIM 5
Getting Unrecognized Card
Enter name of device driver for this card
Network Card in slocket 1
  • Latanya Johnson Nov 18, 2008
    I just purchased the Motorola's LA-4137 802.11b Symbol Spectrum24 LA-4137-1020-WW Wireless Card for my Dell Axim X5
    I keep receiving this message:
    Unrecognized Card
    Network Card in socket 1.
    Can you assist me with this matter. Thank you in advance. 2:14AM CST mstanya0566
    I just purchased the Motorola's LA-4137 802.11 Wlan 2.4 Ghz: Symbol Spectrum24 LA-4137-1020-WW Wireless Card for my Dell Axim X5 I keep receiving this message:
    Unrecognized Card
    Can you assist me with this matter. Thank you in advance. 2:46AM CST Tanyaj
  • 35 Answers
You will recieve this message if the driver for the card has not been installed or has not yet been associated with the device.
If the driver has been installed for the card you will need to enter the proper location of the driver for the card to use it. I cannot tell you what to input as that will depend on the card and driver installed. It might be helpfull to know what type of card you are using (CF/SD) (Wireless/bluetooth/storage/etc), if it worked previously. If you have drivers / installation software
Posted on Aug 05, 2008
Actually the reason why it's saying that is because that card is not compatible with the Dell Axim X5 because if it was you wouldn't get that response. I'm still looking for a Wi-Fi card for mine as well because I ordered the P500 Wi-Fi compact flash card from Dell then come to find out it wasn't compatible with the Axim X5, it was discontinued.
Posted on Apr 23, 2008
Dell Axim X5 connecting to Belkin wireless router
What is the model of your wireless router? Does it support the B network your pda is?
also try installing ministumbler (wireless scanner program) to the pda
available on this webpage
http://www.stumbler.net/
scan around with the stumbler it should detect the network, if its set to the wrong band, G only for example it wont be detected set the router to mixed B / G mode.
Aug 13, 2008 | Dell Axim X5 Pocket PC
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
I have a HP iPAQ H2200 and a just recieved Adtec xi 825 Card but my PDA does not recognize the card! Help?
Hi
I had the same problem.
try this guide
Cyro Chinellato
http://reviews.ebay.com/Prism-3-0-CF-4-DELL-Axim-X5-without-quot-Unrecognized-Card-quot_W0QQugidZ10000000004200583
Dec 28, 2009 | Casio Z-Com LANEscape XI-825 802.11b...
No wifi, how do i get on internet
This model of the Axim X30 does not have built in wi-fi capability. You need to purchase a 802.11 b/g Wireless SDIO card.
IMPORTANT: DO NOT INSERT SDIO CARD INTO AXIM X30 BEFORE INSTALLING DRIVERS.
1. Connect the Axim X30 to your computer.
2. Establish a connection between the two devices using Active-Sync.
3. Insert CR-ROM which ships with the SDIO card in your computer.
4. Follow instructions for installing Driver an Utility.
5. Install SDIO card into the SD slot on the Axim X30.
May 16, 2009 | Dell Axim X30 Pocket PC
Can't install drivers for WIFI card
I purchased a VeriFone 11 Mbps 802.11b Wireless Compact Flash Adapter card for my Axim X5. I put the disc and the wifi card in my laptop and I can get on the internet. But can't seem to get it going in the Axim. It always reads "Unrecognized Card". Tried ActiveSynce and putting the drivers on a different Flash card. No luck..
Mar 17, 2009 | Dell Axim X5 Pocket PC
Unrecognized Card message
Look down the slot in the Axim. One of the pins is likely to be bent. If it can be straightened it will work again but may break.
I had this problem while under warranty. The unit was replaced but that was y e a r s ago.
Jan 10, 2008 | Dell Axim X5 Pocket PC
Wireless compact flash card installation on dell axim 5
Go to Wal Mart and buy a 1 gig SD card----- and then buy a AmbiCom 54G wireless CF card. Works perfectly in my X5.
Oct 30, 2007 | Dell Axim X5 Pocket PC
Symbol spectrum24 wireless network card
I'm going through this myself, and what I've read suggests that the 'install' be run on a PC (XP, NT, 2000 etc) running ActiveSync - the drivers are downloaded to the PPC from the PC. BUT...I can't use ActiveSync, does anyone know a way to get the drivers installed using ONLY the PPC (and a memorycard).
I know, didn't even solve the first problem (just explains why it doesn't work the way it 'should' work) and creating another...
Oct 03, 2007 | Symbol spectrum24 LA 4137 802.11b...
Connectivity/activesync and network issues
When using wireless lan with PPC, there are some experience shere with you. 1. You must do an "Reset" after the first time of installing wireless driver into your DELL AXIM. Otherwise, the driver would not work. 2. Microsoft Pocket PC 2002 only can allow one source to access the internet. It can't access internet via the USB and wireless at the same time. Thus, it is more batter way to leave your AXIM alone instead of insert on cradle when you try to access internet via wireless lan. 3. Some of the wireless's CE driver are based on StrongArm, 206MHz, not PXA250, 400MHz. It will got problem when the wireless try to initiate the link between base station and PPC. Try the following step: (i) Make sure you have been install the wireless driver. (ii) Remove your wireless from CF slot. (iii) start->setting->power->processor select "PowerSave" mode and apply it. (iv) Plug wireless into CF slot (v) If you can get an dynamic IP or access internet, you can repet step 3, but select "Auto" mode. Hoping these information can solve your problem.
Sep 19, 2005 | Dell Axim X5 Pocket PC
Dell Axim X5 Pocket PC Logo
1,003 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
