Question about Pyle PLCD15MR CD Player
Plcd15mr i have bought a pyle plcd15mr but no plug for the back, i need to either find wher i can get a plug or at least a circuit diagram so i can make my own , can you help?
  • 1114 Answers
SOURCE: cant make my PYLE PLCD15MR marine radio turn on.
There is usually a fuseable link in the unit/radio, I would recommend that you check it and replace it.
Posted on Mar 21, 2011
0 characters
1 Points
I have a Pyle PLR14MP that I am installing in my 1975 Ford F100 - There is only one wire to the ignition switch on the radio whereas my old radio had two wires. There is a green wire, a blue wire, a back...
The other wires are for display brightness and memory. In old OEM installations, there is only one wire for each speaker. The other wire is the chassis or body.
Aug 09, 2014 | Pyle PLR14MPF
pyle doesn't offer the manual on their website I would contact them directly here:
thank you and good luck,
Jul 18, 2011 | Pyle PLD-194
PYLE PLCD15MR radio/CD/etc/ Power problems is that there's no power. Connected directly to fully charged (12.3v) car battery. Can't get it to turn on. Double checked everything. Fuse is good. Control...
hello there ,firstly to rectify the power source remove front panel using a multimetre connect (red) positive to pin 1 this is the top pin as you look at the front panel connect (black) negative probe to the 3rd pin and see is there power registering ,if no power is found place front panel back on radio ,remove power block from back of stereo look for the power source wires red/black you will see the pins for these in block test with metre ,make sure while your testing for power the ignition is turned on at all times ,if you are not getting power here there is a faulty wire or the main fuse for radio,has blown this can be located either on the driverside neath the steering column or passenger side check all these fuses aswell ,another thing you could try if all fails try another radio that you know is working this will aliminate power problems ,hope you get it working let me goodluck
Mar 21, 2011 | Pyle PLCD15MR CD Player
Need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
Aug 16, 2009 | Car Audio Receivers
Need a wiring diagram for a Insignia ns-c5112 cd car stereo
you can order one from here:
I had a wiring diagram, but I sold the radio and the diagram went with it.
Apr 04, 2009 | Car Audio Receivers
Having trouble installing my Pyle PLDBT30U
your part number is Metra 70-5520
It is a standard Ford plug, but is used on your car as well.
Only 1 plug is necessary
See link -
i dont think this model has a premium sound upgrade.... could it be a changer cable?
Dec 28, 2008 | Pyle Car Audio Receivers
Pyle PLCD15MR CD Player Logo
21 people viewed this question
Top Pyle Car Audio Receivers Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio Receiver Expert? Answer questions, earn points and help others
