Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
My refegiator wont stay cold ,but my freezer gets cold my cooler grill gets like over iced and blocks the coolair from entering my refegiator .what to do. signed the admiral
  • capgun Jan 23, 2008
    i will wait for the repairman to show , for his advise on this matter. thank you,the admiral.
  • Anonymous Apr 02, 2009
    freezer works fine but fridge wont stay cold
    Master:
  • 619 Answers
Hi, for the meantime the admiral repair man not yet arrive you just defrost so that the ice will melted the cooling fan was shut off due to ice build up.
Posted on Jan 22, 2008
WHY DO THE ICECUBES FROM THE ICEMAKER MELT AFTER THEY ENTER THE ICE TRAY
The icemaker is way colder then your freezer so if your freezer fans are blocked and or you have a full freezer there not gonna stay frozen i have the same problem for instance i have a full freezer but when i buy ice cream or popsicles i put them in the back if not they wont freeze or stay frozen
Jun 12, 2012 | Refrigerators
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
The bottom dont cool
check for ice on the back of wall in freezer section. check to make sure fan motor in freezer turning, if ice on wall you have a defrost problem. bad defrost control or bimetal which is located in freezer section. Check with a ohms meter. should get ohms areading if closed when cold. Last would be a bad defrost heater but rare. Also make sure air returns not block with ice. If so , could be a stop up defrost drain.
Mar 05, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Icebuildupinsidebottomfreezerdoorwaterleakingoutofdoor
The freezer needs to be defrosted. Take everything out and put it in an icechest with some cold packs, and let the freezer sit open and off to allow the ice to thaw, use a pot or something to take the chunks of ice out and put in. Try not to get your floor too wet, but when too much ice builds up, the cooler cannot cool down the air, and the freezer is only staying cold because the ice is there, but the ice will melt since it has no way to stay cold enough to be below 32 degrees without the cooling unit to keep the temperature low.
Dec 13, 2009 | Frigidaire FRS20ZSG
The refigerator does not get cold. Long term ice forms in Freezer blocking through holes. When first pugged in seems to circulate air to refrigerator
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Refrigerators
My Amana BR22V1W Refrigerator compartment 65 degrees F but freezer compartment normal. We just bought a lot more groceries and now both the freezer and frig compartments are quite packed. I don't see any...
Sounds to me like the opening between the freezer and fridge section might be partially blocked!! you get your cold air for the fridge section FROM the freezer side and the thermostat that controls the fridge side might not be opening the door enough,it might be clogged with ice or even not working because of the thermostat setting is not opening the door enough.
Aug 25, 2009 | Refrigerators
FREEZER HAS ICE BUILD UP AND FRIDGE WON'T STAY COLD. ? what causes this and can i fix it?
Bad news, it appears unit is short on gas leak,,,,,Because of this the temp. sensing device over reacts causing the frig to constantly run,,,,also poor door seals do not help,,,,due to costing of repair its better to replace the unit. Water thing bit of a mystery,,,,,could be blocked defrost drain,,,,refrig section of cooler section and just below this is a small drain hole of some description, get a tube or straw and blow down this to clear blockage,,,,,difficult without seeing but hope to be of help,,,,,,,,,,,,,Barry
May 31, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Refridgerator Not Cooling
If top is compleatly warm it is probley the fan motor, lot of failures on them. Replacement one will be a different looking motor. Verify motor is not turning, located in the back of the freezer in the top middle, behind small grill. Will see fan blade pointed up, should run whenever compressor is on.
Aug 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
152 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
