Question about Audiovox BA100 Car Subwoofer
Rampage BA-100 200W amplified subwoofer
Hi, I have one of the above subwoofers. My headunit has preouts for a subwoofer, (RCA jacks) plus the spkr. preouts. I'm powering my spkrs with a 2 channel 800W amp. If I connect the RCA jacks from the head unit sub preouts, to the - and+ on the subwoofer, and run 12V power from the battery, and a ground, shouldn't I have sound from the sub? The directions say to splice your - and + from your spkrs, to your sub. Is this the only way this will work? I can control the frequencies from the head unit. I would like to control the sub from there also.
Thanks
  • choycemoon Mar 05, 2008
    Okay. This powered subwoofer has ONLY the following hook-up ports on the back of it. The power port (that goes to the battery), the ground and a positive speaker port and a negative speaker port. The problem is -- is that in the back of my cd player has RCA pre-amps. I don't know how to convert (or if you can convert) the RCA cables to regular +/- speaker wires. Supposedly this product has automatic turn-on circuitry, so I guess there is no need for the blue or blue/white wire signal turn-on wire thingy. Anyway, I can get this baby to work so at this time... I'm stuck like Chuck... until someone can give me a tip. Thanks.
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Posted on Mar 05, 2008
    New Friend:
My unit has a 6 prong square plug...i have no idea what is what.....ther are 3 poles on the top and 3 on the bottom. witch ones are the power +/- and what are the remaining 4?
Posted on Jul 24, 2010
Choycemoon, that will work, that's how I did mine. I can control the Low frequency, and the Bass from my headunit, which kicks **** bigtime. You don't need a remote switch, to turn on anything. Everything will power up when the key is turned on, and shuts off when it's turned off. Hook it up just like you said, and it will work fine. Once you get it hooked up, and hear it, just for grins, diconnect one of the sub wires, and hear how bad your speakers sound. That little sub kicks ***! Can't beat it for the $.
Posted on Jun 19, 2008
You gotta have an amp on it even know its self powed
    New Friend:
  • 101 Answers
You have too also wire a remote swicn from radio to amp, inorder to turn the ampo on
Posted on Jan 23, 2008
SOURCE:
Subs cut out when bass hits
assuming that both subwoofers are working fine: check what voltage output your headunit has (RCA output voltage) and match it to your amplifiers input sensitivity (GAIN) eg: if your headunit has 4 volt outputs then on this particular amplifier your gain knob would be completely to the left as if in the off or 0 posirion.
if u are not sure of your headunits output voltage you could check the manuals specification page or send me the barand and model number of your headunit and I will check it for u.
hope this helps. let me know if I can assist you any further.
.......andy.......
Dec 26, 2013 | Alpine MRX-M50 - Monoblock 500 Watt RMS...
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
Hi i have just bought a alpine dvd headunit the 105r and it only has 1 phono sub output and not the left and right phono output how do i connect my amp to this
it has 3 pairs of rca outputs, one pair for the front, one for the rear, and another for the subwoofer. the other sub preamp output is not needed to run to your amplifier.
For better sound quality, buy an RCA Y splitter cable (single male connection to double female connections), and run your regular pair of rca cables to the amp.
Nov 03, 2010 | Alpine Car Audio & Video
I have a kenwood kdc-w3541 cd player and would like to wire it to a 4ch amp can you tell me how to wire it....thanks
Your kenwood only has preouts for a subwoofer. If you want to add the amp the amp will need to have some high inputs. If it does not then you will need to buy an accessory that will allow you to connect speakers and have rca outputs. From there yo will need two sets of rca jacks to run to the amplifier.
Nov 07, 2009 | Kenwood Car Audio & Video
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
How to connect a pioneer amplifier to sony cd player in car
easy as matey!
connect RCA leads to the preout in the back of the sony headunit run it down one side of the car into the boot and connect the RCA leads to the amp
You will need to wire in the power earth and remote
Remote lead connects to the BLUE N WHITE wire on back on head unit
Run the power lead and remote down one side of car and the RCA leads down other side which will stop interferance
then just connect the ground and that should be you done
Upfront Audio
May 08, 2009 | Car Audio & Video
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Sub Woofer Won't Work
Connect the input from the powered subwoofer to the rca jack on the VSX-409D labelled 'sub woofer preout'.
Dec 24, 2007 | Pioneer VSX-D409
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
Audiovox BA100 Car Subwoofer Logo
2,445 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
