Question about Toshiba 32AF43 32" TV
Menu appears by itself. Sometimes stays on, sometimes comes on and then off. Also, some of the light touch buttons stay on and you cannot turn the TV on with a remote.
Menu screen comes on and sometimes stays on. Sometimes it goes off and then comes back on. The light touch buttons come on -- stay on, and you cannot turn on the TV without pushing the power button on the set itself. Menu screen comes on and sometimes stays on. Sometimes it goes off and then comes back on. Then the TV cycles through video 1, 2, 3.
4 Suggested Answers
SOURCE: Menu appears by itself. Sometimes stays on, sometimes comes on and then off. Also, some of the light touch buttons stay on and you cannot turn the TV on with a remote.
I had the same problem. Hit menu and turn captioning off.
Posted on Jan 21, 2008
  • 6 Answers
SOURCE: assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Posted on Dec 05, 2008
SOURCE: My remote will not work
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Posted on Mar 19, 2009
  • 3866 Answers
SOURCE: the tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Posted on Apr 22, 2009
0 characters
1 Points
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Standard (CRT) Televisions
My Philips 20PT633 has started shutting off mid program.
Consult your technician there is a semiconductor problem inside your tv. Probably lose connection, and need to resolder.
Jun 08, 2009 | Philips 20PT633R 20" TV
Tv comes on and off by itself, sometimes it blinks on and off. tv is 3years old. i put all my cords on a power surge . i recently put a dvd on my tv. need help to see if i need to buy another tv?
rca tv alway have that problem. you could try to clean up all control bottom in control panel or change all.if not. best thing you take down all bottom then only use remote control to operation that tv. good luck!
Jun 01, 2009 | RCA TruFlat 27F520T 27" TV
RCA TV, model number 32V550T. No picture but sound is fine.
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
Feb 24, 2009 | RCA 32V550T 32" TV
Screen is black but sound works
possible lamp is burned out,look in your manual for info.
Jun 26, 2008 | Samsung DLP HL-P5663W 56" TV
Magnavox MS3252S431
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
i have the same trouble,i found sometimes i can unplug it and plug it in a few times and it will turn on but it dosnt do that even so i am taking it to a technician
May 17, 2008 | JVC AV-32D502 32" TV
Takes sometimes up to 7 times to get TV turned on and to stay on with a picture
I believe you have a loose conection in the horizontal deflection circuit,a good place to start checking is the horizonatl driver transformer ,horizonatl output transistor and output transformer,one thing to try is taping on side of the set to see if it reacts and does something different,If you are familiar with tv service this information will give you a place to start but if you are not too familar see the assistance of a servicer,it should not be expensive.
Oct 15, 2006 | Philips 32PT543S 32" TV
Toshiba 32AF43 32" TV Logo
26 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
