Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Won't turn on WS 55513
I replaced the 4 capacitors om the DM. The green light blinks for about a minute then goes out. What can i do now?
  • Jeretn Jan 23, 2008
    Already checkerd those they are good. Thanks for the response.
  • Mitsubishi Master
  • 8,617 Answers
Check the pico fuses on the back of the circuit. see if one has blown that seems to be another symptom on the WS models. They are little tiny ceramic fuses soldered to the runners themselves. hope this helps.
Posted on Jan 22, 2008
Blinking green light
Common problem with some capacitors blowing in the DM module. Its a failry easy fix if you have the right parts and insructions. Goto and get their blinking green light kit.
Sep 23, 2010 | Mitsubishi WS-55513 55" Rear Projection...
The green light on my tv are blinking and the tv wont turn on
Get a blinking light repair kit from - this model has some capacitors on the DM board that need to be replaced.
Apr 11, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Dec 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Sep 02, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Won't turn on
Do a search and you will find a lot of us that had the same problem. The issue is probably 4 bad capacitors on the DM board. The parts to fix it cost about $2.
There used to be a "how-to" detailing how to do this repair, but I can't find it anymore.
These are the capacitors you need..
part number - P13119-N
get them here..
Mar 29, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS 55809 Rear projection TV
replace DM
Picture of bad caps
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 55" tv problem
When it shuts down, try pushing the input and menu buttons together on the tv and hold them for 5 seconds , and see if it blinks a 2 digit code . If it does let me know the sequence of the blinks. If not then its not going into protective shutdown, so its probaly one of the low voltage regulators. Let me know what you discover with the input and menu buttons.
Jan 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
