Question about Acer Aspire 3100-1405 Notebook
No wireless connection
Trying to connect to internet via Acer 3100 laptop.... no connection
  • fast23 Jul 01, 2008
    I get wireless connection at home, however when I take my laptop to the trailer park it will see the connection but will not connect, i have tried everything. Help please!
  • Anonymous Dec 14, 2008
    i can not connect to my router so i can not get on to get on to the internet
    Novelist:
  • 123 Answers
If you are having trouble connecting to a configuring your wireless router it is generally something simple. These are the most common reasons.
Is your computer WiFi enabled (does it have an adaptor)?
Is the login information entered correctly?
Are you using a firewall?
Are you using connection profile software (many times this is installed when you install a new adaptor)?
Are you adaptor drivers uptodate?
Is your operating system up todate?
More detailed troubleshooting steps:
Does your computer 'see' the network?
Does it see the signal? If it does are you pulling a valid IP address (192.168.X.X)? Also known as connected, no surf.
Check your Internet connection with a another computer.
Check for firewalls or security software.
Are parental controls turned on (controled through your browser or firewall)?
Check your browser.
Try to completely re-move and re-create the connection.
The computer 'sees' the signal but does not pull a valid IP address.
Are the WEP Key and SSID entered correctly?
Are you using connection profile software?
Check the adaptor Configuration.
Up-date the adaptor drivers.
Check the adaptor.
The computer does not 'see' the signal at all.
Try from differant locations in the park.
Check the adaptor.
                           or
   Wireless Configuration for Windows XP
802.11b technology enables computers equipped with Wireless LAN cards to join a wireless network. Follow these steps to configure your PC with Windows XP to use its wireless card. You may use the links below to jump directly to a particular step in the setup process.
Verify that the Wireless hardware is working.
Verify that your Wireless card is registered with DHCP.
Configure TCP/IP to use your Wireless connection.
Configure your Wireless card to use the University Infrastructure.
Test your connection.
Generally speaking, you will not need to register your card for DHCP. Instead, order for you to access the internet from your wireless card, you will first have to authenticate via a web page. This page will automatically launch if you have not authenticated. However, there may be some locations that still use the DHCP method for determining whether or not you are able to access the internet.
If you are not sure what areas are not configured for using the authentication method and which are not, you can register your card for DHCP service. It is free, and will not adversely effect other wireless services. There are online directions (http://www.umn.edu/adcs/network/dhcp.html) for registering your card with NTS. You will be asked to enter the MAC address for your card. Keep in mind that it takes 1-3 hours after you submit the form for the registration to take effect.
The TCP/IP protocol is used to connect your computer to the Internet. The ethernet install instructions should have guided you through the installation and configuration of TCP/IP for your operating system. You may wish to refer to those instructions again. Make sure you set the card up to use DHCP.
Configure Wireless Card to use the University Infrastructure
Windows XP has changed much of how a connection is made. This is true whether it is a wireless connection or any other connection. This change has made it somewhat simpler to access the wireless network. However, for those unfamiliar with this new way of doing things, configuring the wireless card can be a bit troublesome. The first thing you will need to find is the "Properties" of your "Network Connections" The simplest way to get to this location is to right click on the "My Network Places" icon and select properties.
You may notice that there is an "X" next to your wireless connection. This is expected. It shows that your wireless card is properly installed, but you have not as yet connected to a wireless network. You need to right click on the wireless network icon, and select "View Available Wireless Networks"
You should see a list of available wireless networks. If you do not see "UofM Wireless" then you need to get into range of a University Wireless Access Point such as one by a kiosk.
In some instances, you may be using "Wire Equivalent Privacy" or WEP in some special cases. The University infrastructure does not implement WEP, thus you will be informed that the wireless connection is not secure. If you select "Allow me to connect..." you will then be connected to the University's wireless system.
It may do some things, but an icon in the lower right hand corner of your desktop should eventually appear stating that you are connected.
You are now ready to authenticate to the University's Wireless system. If you have set your connection up for DHCP, you should be able to browse the internet at any of the wireless area networks around campus.
Test your Wireless connection
To test the TCP/IP protocol, open your web browser (Internet Explorer or Netscape). You should see the wireless authentication page come up. If not, verify that your wireless card is working properly. (See the first step in this document).
NOTE: Even if you are planning on using another internet resource such as SSH or other service, you will still need to launch a web browser first and authenticate. After authentication, you will be able to access those other internet programs as you would normally.
If you have other Networking cards, you may want to remove them. The system will try to use all Network cards bound to TCP/IP. If a network card exists, but isn't attached to the network, it may try using that card to access the Internet.
You can type "ipconfig /Release" and "ipconfig /Renew" at a command window on Windows XP machines. This will attempt to communicate to the DHCP server. If an IP address is available, you will be assigned one quickly. If not, then the AP may be having problems, and you should try another location. If it works at another location, please contact the helpline about the problem. (612)301-HELP
Posted on Jan 27, 2008
  • Anonymous Jan 27, 2008
    it will surely work
I already make a format to my computer put the wireless not working
Posted on May 19, 2008
What is athcfg11
Posted on May 11, 2008
6ya staff
SOURCE:
Acer Aspire AS5552-3691 LX.R4402.149 cant connect to internet
Make sure the built in wireless for this laptop is turned on, via a physical switch or using the Fn key in combination with the proper function key with the wireless icon.
If still no connection, check the source you're trying to connect to. Make sure your router is working properly and see if other devices can connect to it.
If your source is operational, and you still can't connect, two things might be happening.
1. You may have a virus on the laptop called a ******, which will block your internet connection
or
2. Your wireless card may be failing.
Download some virus removal software (Malwarebytes, SAS, Combofix) and try to remove the viruses. In the end, the best thing to do is take it to a trained computer technician so you don't accidentally delete something you need off the computer.
Sep 12, 2011 | Acer Aspire One PC Notebook
INTERNET
Are you having a problem connecting to the internet? Are you trying to connect via LAN or WIreless network?
Mar 02, 2011 | Acer Aspire 7741G3647 Notebook
Can not get wireless connection on asus notebook
Try resetting the network adapter.
On the bottom right hand side of the desktop you will see the wireless icon, right click on that ans click on troubleshoot problems. This will reset the adapter and assign an IP address for your your PC.
When its done try to connect to the internet.
If this advice does not help please post back.
Good luck.
Jan 11, 2010 | ASUS m6n Notebook
I had ACER ZG5 note book. How can I set up a wire less internet connection on it?
you need a wireless router to connect via router. just put your internet/broadband/modem cable in WAN port. and then you'll be able to connect via wireless.
regards
Best of Luck
Nov 03, 2009 | Acer Aspire One A150-1006 Notebook
I have an Acer Aspire 3100. I can not connect to the internet.
Try visiting the Windows Update page.
Usually when I have problems like this after a few updates the problem disappears.
Is the wireless network password protected?
Jun 18, 2009 | Acer Aspire 3100 Notebook
Connects to network, strong signal, will not connect to internet.
it looks like wireless card in the laptops need to be changed.
Jun 03, 2009 | Acer Aspire 5610-4648 Notebook
Connetion error
Check for drivers regarding wireless and disconnect the internet and first connect your laptop via wireless and then connect the internet ping your modem and router it should get a reply
Mar 03, 2009 | Computers & Internet
Problem
in travelmate of acer,the wireless connection is built-in what your going to is to configure it.Go to the wireless connection icon it is located in the right-down of your laptop.right click,then click the status,then click connect.your notebook will automatically find the nearest connection of internet
Oct 26, 2007 | Acer TravelMate 2300 Notebook
Acer Aspire 3100-1405 Notebook Logo
546 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
