Sound problem I've turned off the main speakers on my vista desktop and can't find a menu in sounds to turn them on again...
    Genius:
  • 1,067 Answers
Go to control panel
then switch to classic view ok the u see speaker icon clik on it unmute it turn it up whatever u have to do ok dont forgetto rate this as fix ya if it works for u so other pp can see
Posted on Jan 22, 2008
Sound speakers
Surround Sound speakers? Internal or External? Where are you plugging the headphones in?
May 30, 2013 | Lenovo G570-4334 -24828
My tv has no sound when turned on and I've checked all possible menu solutions, mute issues, etc. What else can I do?
unplug from the mains and open up the cover to check for the possible open wires in the speakers. measure the speaker windings to ensure its not open or not shorting.
there could also be a possibilty of a sound ic blown due to excessive supply voltage. in the sound output region you`ll find sound output ic ``TDA`` which should be replaced to restore back the sound
Sep 17, 2011 | Televison & Video
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
Hey, I've got an HP Compaq D530 SFF desktop machine whose sound card uses the SoundMAX drivers. The problem is that when I connect earphones/headphones on the front panel, and try to listen to music or...
if you go to the bios (restart computer and press del to go to setup) you should be able to look around and find the option for internal speaker. Set that option to disable and do not change anything else unless you know your way around. Save it and restart afterwards and it should disable the internal speakers.
May 06, 2011 | HP Compaq Evo d530 PC Desktop
I have a Acer Aspire T671 PC Windows Vista I hav lost sound from the PC, my sister was on it and started clicking all amnner of things and suddenly then sound was lost. I have tried going through different...
no sound
software problem -go2 device manager &under device if u see yelow ? mark so tht driver is missing from my computer REINSTALL IT
Else hardware problem thn Replace speaker
Feb 21, 2011 | Acer Computers & Internet
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
My sound hardware work but i dnt hear nothink in my output speack
Question: Are your speakers plugged in and turned on?
First check the hardware of your speakers, that they are plugged in, to the proper speaker port. then check the device manager to see if it recognizes the sound card /speakers, it not then go to add hardware app and run it , remove sound card and replace it with windows Plug and Play running. if it recognizes it then run your program to see if the sound is playing. Good luck hope this solves your problem.
Jul 12, 2009 | Computers & Internet
I have a creative audigy Creative Labs Sound Blaster Audigy 2 Sound Card and Creative 7.1 surround sound speakers. When I was using XP all 7 speakers worked perfectly. Now with my newer Vista machine,...
Uninstall all sound drivers for the card. Delete all folder and use search to locate everything related to the sound card. Remove card , turn comp on w/o card. Turn off reinsert card.
Should fix it.
Vista has many,many issues like this.
If you have more types of sound listed in "SOUNDS" delete all but Audigy.
Re-install drivers AFTER you get ALL NEW VISTA UPDATES>
Mastersage
Feb 18, 2009 | Creative Labs Sound Blaster Audigy 2 Sound...
Speakers have no sound
uplug speaker cable and plug it again
Mar 16, 2008 | Dell Dimension 2400 PC Desktop
110 people viewed this question
 Grubhead
Grubhead
