Question about Lexmark X73 All-In-One InkJet Printer
No ink on paper
Didn't use my printer for 2 months. Now it prints, but nothing shows up on the paper. is there some way to get the ink flowing again?
  • BFW61 Jan 30, 2008
    Just tried cleaning the print nozzle. Not sure what the paper is supposed to look like when it's finished. Did it multiple times just to see if there was a difference. Then tried a test print and nothing was on the test page. Any other ideas? I'm realllllly stymied by this. Have never had this problem before after lengthy inactivity.
SeaJade,
Thanks for your response. I refilled the cartridge 3 months ago and all was going well. The printers software says it is full.
The printer is a Lexmark x73 all in one inkjet. It has a black and white cartridge and a color cartridge.
I may have to just buy new cartridges, but they are sooooo expensive, I wanted to try all avenues before that expense. I've also tried cleaning the cartridges with the cleaner that came with the fill kit.
The printer is about 4 years old...it was a freebie when I bought my Dell computer. Maybe it has lived it's life?!?! :-)
Thanks again for your help!!
B.
Posted on Jan 31, 2008
    Scholar:
  • 104 Answers
Hi, Have you tried doing a print head clean. Sometimes after periods of inactivity the heads can become clogged.
Let us know how you go.
SeaJade
Posted on Jan 26, 2008
  • Jade Rallings
    Jade Rallings Jan 31, 2008
    Hi, Ok, the next thing is the actual ink cartridges. When did you last change them and does your printers software enable you to see how much is estimated to be left. Also depending on the age of the cartridge the ink may have dried too much for it to flow. How often was the printer used prior to 2 months ago? It may have already been getting too dry.
    What type of printer is it, make and model does it have a multi cartridge or separate tanks?
    Let me know how you go,
    SeaJade
Black ink printing incorrectly. Blank lines are showing in the middle of a line of printing. I have cleaned the print heads, alligned and calibrated. Nothing seems to work. In fact, calibrating made...
Hi
Try to clean it manually by removing the ink cartridge and then clean the print head with softcloth with rubbing alcohol. Then rub again the printhead into a plain paper until ink flows. Then try to print again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 20, 2011 | Canon MultiPASS MP370 All-In-One InkJet...
My black ink is not working please tell me how to clean it
Hi
To clean it, remove the ink cartridge and rub the print head into a plain paper with rubbing alcohol until ink flows. Then run the print nozzle for 2 time for further cleaning the print head. Then try to print again.
Another way is to soak the print head only into a how water for 5 minutes until ink loose up and ink flows, rub the print head into a plain paper with rubbing alcohol until ink flows. Run the print nozzle and then try to print again
Post comment for more help
Mar 18, 2011 | Office Equipment & Supplies
Just put 2 new ink cartridges in my printer - black and tricolor. the printer receives the message to print, sends the paper through and sounds like it is printing, but then the paper is blank with no ink...
Hi
Just remove the new 2 cartridges and rub the print head in a plain paper with isopropyl alcohol until ink flows, and then return the ink cartridges and run the print nozzle for 2-3 times. After that, try to print again.
Please let me know if you need more help.
Mar 05, 2011 | HP OfficeJet D135 All-In-One InkJet...
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
NOT PRINTING BLUE INK
Sounds like the cyan print head is clogged or you are out of cyan ink. You can try running cleaning cycles with your printer or you can try to clean the print head yourself. To clean it yourself you will need dry paper towels and papers towels moistened with warm water. First rub the print head with the wet paper towel, then press the cartridge into the dry paper towel to see the three color bars (a good print head will have three solid fat color bars). Then you can try resting the print head on the wet paper towel for about a minute to get the ink to flow out (do this on a surface that you don't care about, ink stains). Then rub and blot the print head on the dry paper towel. Continue until the cyan flows again (if after 2-3 tries it isn't flowing you probably won't get it flowing). If you go to a Cartridge World store they have equipment to get print heads flowing again and they should clean it for you.
Jan 07, 2010 | HP DeskJet 6127 InkJet Printer
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Acts like it's printing, ink is good, but nothing prints out on paper.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
I have a dell printer A960 I refilled color cartridge and have not used it for about 2 months and now it only prints in red what can I do
The print heads on your ink cartridges have dried up. Ink printers need to print in black and white and color once a week. Doing this will extend the usable life of your cartridge because the ink will not dry on the print head and clog it. You can try and get the ink flowing yourself by resting the print head on a warm moist paper towel until you see ink on the towel (ink stains most surfaces so be careful where you do this). To check your progress, press the print head into a dry paper towel. You should see three entire distinct colors for the color cartridge and one black line for the black cartridge. If you can't get it flowing again you will need to buy new cartridges. You can get Dell refills from Cartridge World if you would like to save some money.
May 11, 2009 | Dell 946 All-In-One InkJet Printer
Restart after replace ink cartridge
my CX4800 has done the same thing. I ran the utilities dozens of times, replaced every cartridge and it feeds papers the print head moves like it's printing but nothing is imaged on the paper.
Searching the web is my last chance to fix it before i toss this 18 month old printer and never buy an epson again.
Aug 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Wants to print but won't put ink on paper
I'm experiencing the same problem. I tried to troubleshoot through software that came with printer, but no luck. Here's what happens:
The printer worked great for a month or so. Then, I didn't use it for a few months. When I tried to use it again, it acts like it's printing. My computer shows it's printing, the printer runs through all the steps, including moving the print cartridges back and forth over the paper as it should, but no ink comes out on paper.
Any suggestions?
Nov 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
