Heating & Cooling Logo
Posted on Dec 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our 30,000 kerosene heater runs for about 1hr then shuts down.we reset it and it might start & run for 5 min. or might not start untill cool. this is a Reddy Heater Model R30 spec # 5068G01 not the R40. Thanks Art
Anonymous
Level 3:
Prodigy:
An expert who has answered 500 questions.
  • Master 540 Answers
  • Posted on Dec 18, 2009
Anonymous
Master
Level 3:
Prodigy:
Answers
540
Questions
Helped
190348
Points
1000
Time for a new kit at your local lawnmower shop.
Spark plug fired,( Sears -30,000 BTU) starts and runs for approx. 30 seconds, then cuts off. The reset button does not reset for restart for about another 20 - 30 seconds. Then the unit will restart...
check and see if the heater has a high temperature limit switch. if it does it will shut the machine off until it cools down.. just replace it with a new one.
I have an older 30,000 BTU spark plug type kerosene Reddy Heater. My problem is this; The heater will run for an hour or so then shut off. It seems as though it needs to cool down before it will allow me...
http://www.reddyparts.com/FAQ_spark_plug_heater.htm
Try the link below. You can run down the list of checks and also get parts. You need to repalce the nozzle or clean it yearly. If it's older replace plug too. Check pump pressure.
1helpful
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Kerosene heaters run for 30 mins then shuts off.
Sounds like the pump or air filter is dirty. If cleaning them doesn't help, the pump will need to be rebuilt.
2answers
Look below
make sure air and fuel filter are clean.Set pump pressure to mfg set pressure after two minutes of operation
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Reset button keeps popping and the time between becomes shorter.
check the photo eye. It's the little rubber boot on the bottom right on the back side of the burner. If it's dirty, it may not be shutting off the igniter. If the igniter runs continuously, the safety breaker will trip.
Reddy heater pro 110
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Htr shuts off after awhile and won't come back on till it's cooled down
I believe your heater has a solid state relay to start the motor when the motor gets to speed it is supposed to shut off. It may be stuck in the on position.
Top Desa International Heating & Cooling Experts
Paul Carew
john h
Jay Finke
Jay Finke
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
