Question about Alpine CDA-9856 CD Player
Sound Issues I hooked up my alpine cda 9856 and when I turn my radio up past 22, the sounds seems to fade...also, when I hook my IPOD 30G up using the alpine IPOD cable the sound only comes out of the passenger side speakers. I don't know if anyone else has the issue but what can I do to resolve the problems.
  • apin_ouch455 Feb 15, 2008
    Yes I have same issue.... when volumme turn up pass 24....it cuts the sound down.... what is up with that?
  • Anonymous Jan 17, 2009
    Alpine cda-9856, bought the head unit right and put it into my work truck w/PPI275 amp and 2 newer Keenwood 10's. I know for a fact that amp is in good working order and so are the subs but having the same issue as you are w/ head-unit. Anything past 22 on volume w/Bass @ -7 and BBE off really sucks. Anything 22(volume) and below sounds really good. HEALP ME
  • 11,896 Answers
The player has a built in safety device which only allows it to turn up so high. It help to avoid burning out your equip ment. Best way is to put sound on one device 3/4 ways up and then use the other device for adjusting the volume from there.
For sound in one channel; either there is a wire unplugged or not getting a good contact, or the player is set for mono instead of stereo
Posted on Jan 16, 2009
Radio and CD is on but no sound. all amenities show good.
have it hooked up right on the system? are all wires good?
Feb 24, 2013 | Alpine CDA-9856 CD Player
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Apr 17, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Problems with amp or stereo
check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
Jan 16, 2009 | Alpine CDA-9856 CD Player
Alpine CDA-9856
Do you have to run in AUX to get XM Radio? Your receiver and unit sound like its ok. This could be a problem with your provider. Contact your provider and their tech dept can help you organise a solution. Is your radio, XM ready?
Mar 09, 2008 | Alpine CDA-9856 CD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Works fine through 4 chnl. amp on radio until you switch to cd then rear speakers turn off
You have the amp hooked to the "Antenna turn on" which is the blue wire.... you need to hook it to the "REM" output whis is Blue with a white stripe.
Sep 04, 2007 | Alpine CDA-9857 CD Player
Alpine CDA-9856. Search button for IPod will not bring up menu
I have the same problem with a CDE-9870R and my iPod. I tried my daughter's iPod, and it works. I did not search any further, but it may come from the iPod software version. Mine is more up-to-date than hers (5th generation iPod 1.1.2 2006-06-28 update).
Mar 26, 2007 | Alpine CDA-9856 CD Player
Alpine CDA-9856 CD Player Logo
202 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
