Dvd video player model no DVP3120 unable to get player to play on tv setting AV1 at all but on tv setting AV2 player plays dvd`s but picture only no sound. it is connected using a Scart lead.
Through a process of elimimation I identified the problem as a faulty scart lead
replaced lead and all was okey dokey
thanks for advice posted
colin the cat
Posted on Feb 07, 2008
Can't find AV1 on menu
You can Convert the DVD to Video OR Convert DVD to Flash,play on PC.
Nov 20, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Jan 20, 2011 | Televison & Video
Hi, If your TV and player have : AV1, AV2, S VIDEO, HDMI; you can test one by one the connection to get them work. May be some of them unable to works.
Dec 08, 2010 | RCA Televison & Video
My dvd player works and plays movies but i changed the video to s-video and now i can't see anything on my screen just able to hear movie play. how do i reset it back to normal video?
Make sure you're tv is set on S-VIDEO, not AV1 or AV2 or VIDEO 1 or VIDEO 2, etc... there's most likely a setting on your tv to select your input to S-VIDEO.
Oct 09, 2010 | Toshiba SD-4100 DVD Player
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
I am receiving no picture when I play the dvd
check cables.check for video mode on remote
Jul 08, 2009 | Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
I have a kenwood kvt-m700 dvd player that gets sound but no picture when i try to play a dvd
The only way to play DVD's on your M700 is to have the handbrake on. Although you can get round it by plugging the DVD into the second set of connectors (AV2) instead of the first (AV1).
May 05, 2009 | Kenwood KVT-M700 Car DVD Player
DVD is hook up and no picture on the TV.
You have to make sure that the RCA cables are properly connected to the TV. Check the TV/Mode if it's set to AV1 (Audio/Video1) or AV2. You may check the TV remote to set it to AV1 or AV2.
From the DVD, the cable should be connected to OUT. And on the and audio should be connected to IN.
Apr 05, 2009 | JVC XV-S300 DVD Player
DVD player only plays DVD in black and white - what's wrong?
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
