Question about LG CHOCOLATE VX8500 Cellular Phone
LG8500 I have an LG8500 phone i can make calls from it, but when i press the menu bottum the phone freezes up. The this a new phone
  • 3 Answers
Are you using an SD card? If you are, it's probably corrupted. You need to format it.
If you aren't, try turning off your phone by removing the battery. then try again if the problem still persists see technical support .
Posted on Jan 31, 2008
Virgin mobile
1. Find "Change password"
  • Press Apps.
  • Press Phone.
  • Press the Menu key.
  • Press Call settings.
  • Press Additional settings.
  • Press Call barring.
  • Press Voice call.
  • Press Change password.
2. Change barring password
  • Press Old password and key in your current barring password (default is 0000).
  • Press New password and key in a new barring password.
  • Press Confirm password and key in the new barring password again.
  • Press OK.
3. Exit
  • Press the Home key to return to standby mode.
Mar 19, 2014 | Cell Phones
How to add to rejection list button to my call log
First click your phone icon to bring up the dialer, then click your "menu" icon on the bottum left.. from there you get your call settings.. you can click on call restriction and then create new, and select from the source you want.
Nov 27, 2012 | Samsung Galaxy S3
How do i block incoming phone call from a uniden cordless phone
  1. Block an Incoming Call
    • 1 Wait until your phone rings and displays the caller ID information 2 Press the "Block" button on your handset.3 Press "Menu/Select" or "Block" to confirm your decision.Block in Standby Mode
    • Press the "MENU" button on your phone's handset.
    • 2 Press the down arrow button to select "Call Blocking." Choose "Create New," "Private Number" (block private calls) or "Unknown Number" (block unknown numbers) from the list.
    • 3 Enter the 10-digit phone number, if creating a new entry. Otherwise, press the "Menu/Select" button to confirm your choice
Oct 14, 2011 | Uniden Cordless Phone
H,i I tried to give a hard reset my phone but pressing the key recovery and has a symbol on the screen, now does not respond, how long should I wait or should it be immediately?
Did you press the MENU.
Follow the following steps:
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, andthen re-install it. After re-installing the battery, turn on the phone.
Mar 17, 2011 | HTC Hero Smartphone
For some reason i cannot access the menu on my e71 i press the menu button and the phone just doesnt do it and freezes if i turn the phone off and turn it back on again it will work i brought the phone...
for some reason i cannot access the menu on my e71 i press the menu button and the phone just doesnt do it and freezes if i turn the phone off and turn it back on again it will not work
Jan 27, 2010 | Nokia E71 Smartphone
Brother mfc-8860dn, unable to reset maintenance message, after fitting new rollers
TURN THE PRINTER OFF PRESS AND HOLD THE MENU BOTTUM AND TURN ON /KEEP PRESSING UNTIL YOU SEE MAINTENANCE
THEN YOU PRESS 82 FOR DRUM OR 88 FOR THE FUSER OR THE KIT.IT FIX YOUR PROBLEM.
SORRY ABOUT MY ENGLISH.
Jun 24, 2008 | Office Equipment & Supplies
LG8500 Error :G-65
i bought a new phone ...no flashes ...just new phone same alarm so your flash had nothing to do with it
thewiz453
Jun 14, 2008 | LG KG800 Cellular Phone
How to unlock a lg8500(telus)
I had same problem , Call your phone company ask for the Techincal Support tell them that you were just speaking with another represenative and that they told you to update your roaming list they will give you instructions once they give you a number (for telus ) I belive its *8067 or somthing similar then check the options your phone gives you there should be an unlock option same with verizon except u call Verizon Customer support
PS urwelcome :P lol
Mar 27, 2008 | Cell Phones
Centro GSM unresponsive at times
My Centro doesn't respond ("freeze") on incoming calls up to 10 times a day. The "answer" button (on the screen) and green "send" button (next to "phone") block and it is impossible to accept the incoming calls. It is necessary to perform a soft reset to solve the problem temporary. Even after hard reset the situation is the same. This is very frustrating for a new device. Sometimes, frequent callibration of the screen from the "Preferences" menue delays the freezing effect. AFAIK the problem is software-related, considering the recovery after reset. Is there any update on the palm support page / forums, related to the problem? I couldn't find any. From time to time, there is onother problem I experienced - from the contact menu it is difficult to dial the selected number. Sometimes it is necessary to press “dial” several times resulting in significant delay.
Mar 19, 2008 | Palm Treo 500 Centro
Problems with nokia 3230
reformat the phone... try key in this code *#7370# or switch off, then press *, 3 and call button while switch on the phone keep pressing until you see the word formatting... if not, keep trying, it might not working for the first time due to pre releasing the buttons..
Apr 23, 2007 | Nokia 3230
LG CHOCOLATE VX8500 Cellular Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
